Question about Teac Audio Players & Recorders
Teac AG-D7900 avr factory reset - Teac Audio Players & Recorders
Posted by taso pap on
My Teac AG-10D resets to fctoryy default after every power off. how can we save setting
Hello Amjad, question, how does the shutdown, from the remote control, in the equipment itself or cut off the power supply? and if you cut off the power supply, for how long?
Because depending on the time and how it is turned off, you can lose the parameters and settings and go into mode, factory settings
I send you a link to download the Teac AG-10D user manual, there it tells you the adjustment procedures and memorized them
I hope my comment has served you
Greetings Franco Dosil
Hola Amjad, pregunta, como hace el apagado, desde el control remoto, en el propio equipo o corta el suministro de energ?a? y si corta el suministro de energ?a, durante cuanto tiempo lo hace?
Porque dependiendo del tiempo y forma como se apaga, puede perder los par?metros y ajustes y se pone en modo, Ajustes de fabrica
Te env?o un link para que descargues el manual de usuario del Teac AG-10D , ah? te indica los procedimientos de ajustes y memorizado de los mismos
Espero te haya servido mi comentario
Saludos Franco Dosil
https://www.manualslib.com/manual/744985/Teac-Ag-10d.html
I have this issue, my teac ag d7900 which itself off to standby and when I switch it "on" again, it says protect and shut itself down again
Right. This means that either you have a short in your speaker cable somewhere or the short-detector circuitry inside has problems. Disconnect all speaker cables and turn the receiver on. If the symptom goes away, turn the receiver off again and connect one of the speaker wires. Repeat until it starts to go into protect again. When it does, the last speaker you hooked up has a short somewhere in the wire.
If protect always comes on, you'll need to get the unit serviced.
Sorry, I would like to know if you connect the rear L/R speakers to the back of the subwoofer will it work??? Thanks
That would depend on the subwoofer and its connections, wouldn't it? What does the unidentified sub's manual say?
If the sub is just receiving LFE you wouldn't magically get L/R Rear out of it. Manuals.
Can I connect an active speaker to the Teac AG d7900 output
http://produto.mercadolivre.com.br/MLB-184407791-av-digital-home-theater-receiver-teac-ag-d7900-_JM
It would have helped to know something morwe about the 'active' speaker.I imagine its manual would tell you what it needs for input.
Active speakers are usually designed to be driven by volume-controlled Line Level inputs. This receiver has none except for the Subwoofer PRE Output.
4helpful
I just want to know the wattage on the Teac AG-V3050
Teac AG-V3050 and Teac AG-V8050 are very compatiable to help with this question the total watts per channel are 100 watts. Hope this answers or at least helps. Excellent unit, great power to supply great sound for the unit at its time.
I need a user manual for a AG-D7900
User and Service manual available HERE.
Or eMail [email protected] with your manual request.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Playing a dvd...getting music and background sound, but no voices...help!
Go into the receivers "main menu" check your "center channel settings" if you don't have a center channel, make sure it's set to "off or no" If you have one, make sure it's on. If you still have an issue, post a comment and I will help you troubleshoot further. Hope this helps.
2answers
TEAC AG-D7900 Amplifier remote controller not funtioning
http://remotes.com/
They can be expensive but they have just about every remote you could think of.
Please don't forget to rate
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
