Unable to receive calls. Can call out. When call from another phone it says party is not available. If you wait it tells you your call is being transferred. Then I can pick up & answer.
I believe someone accidentally changed settings. This is on our office phone. Avaya Euro 18D phone
Just unlock your blackberry network, call your original phone network and make request about blackberry bold 9000 unlock code, they will charge some money to you and you need to wait for a couple weeks before you get that code. Or you can buy blackberry unlock code from third party sites with lower cost and you just need to waiting in minutes.
This is a standard phone so I'm assuming you're using this in a home or small office, connected direct to a regular phone line, and that you're using calling services from your phone service provider. 3-way calling works as you describe: you press flash to get dialtone again, call the other party, then press flash again to connect the two so all three of you can talk. The point is that this is 3-way calling, not a forwarding or transfer function. You can't transfer a call to another number this way. Since you initiated the 3-way call, the connection requires you to be there; when you hang up the connection between the other two parties is broken.
Your line may also have call-forwarding, which lets you program a number that calls to your line will reach if you're away (an alternative to using voicemail or an answering machine and needing to check messages). But this doesn't allow you to transfer a current call to another number, only incoming calls.
The only way you can transfer a call is when you have the switching equipment (an office phone system, for example) at your location, and have at least two outside phone lines available. Then the system would allow your phone to disconnect, and still maintain the connection between the other parties. But both of the phone lines would remain tied up until the other parties hung up, and if you only had two lines you'd be unable to receive or make any other calls.
Residential customers with a single phone line don't have any option to transfer calls.
My Bluetooth is not working in N73 mobile .When i turn on my bluetooth this error msg appears " unable to perform bluetooth operation
then plz help me someone
The specs list "Call waiting " as one of the features (see: http://www.philips.ca/c-p/SE7450B_37/-/specifications) but the manual (available in the support tab) doesn't show any way to do this.
I'd recommend asking the Philips help centre, hopefully they'll be able to tell you how to do this. If they can't, point out that you bought it with the expectation of this feature working given that they list it as a feature (listed under Convenience/Call Management at the link above). They might be able to swap it for a model that can. Or refund your money. And fix their specs page. Intercom hold/transfer is not really call waiting.
Good luck.
