Ovens Logo
Question about Ovens Ovens
Decor ERD48SCH display stopped working. Light works, panel beeps as normal, but cannot turn on ovens or other bake controls.
Decor ERD48SCH display stopped working, after breaker reset it worked fine as did ovens and timers. Died 3 more time, and reset successfully. After fourth failure, breaker did not reset display. Display no longer working, and cannot use electric ovens. Light works, panel beeps as normal, but cannot turn on ovens or other bake controls. How do I troubleshoot?
Posted by Daniel Villanueva on
Turned oven to bake it keeps beeping with message "door"
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
How to Get GE Oven to Stop Beeping eHow
2answers
Thermador CM301U Microwave cook smart, self clean and proof buttons all make the display light up as normal, but probe, convection, bake, broil and roast do not. I can hear the beep but nothing on the...
there are two boards in the oven and i would think that it is the one on the left called the secondary . if you remove the display panel you will find the tech sheet and this should help diag the problem . thermador does use fault code's and if any have displayed / in the tech sheet you will be able to tell whats going on or in this case what isn't .. mm hope this helps .. feed back pls .
Whirlpool electric double oven #RBD305PDQ14 control panel blank
I suspect a poor connection at the wiring to the EOC is the cause of the failures.
Whirlpool Double Oven RBD305 Display doesn't show, oven wont work
Most definitely a bad control board and/or soldered components. (The part about cutting power to the oven was a dead giveaway)
There are low and high temperature solders, but usually solder melts at 370° F. If the oven is improperly insulated or ventilated you will have continued heat stress to the control board.
Err on display when I try to set the bake temperature
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
or try doing this
1. Turn the clock selector knob to OFF
2. “Tweak” the oven control by turning the clock selector knob slightly to the left (counter clockwise). This may stop the flashing message/beeping and clear the display window.
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
2helpful
4answers
Whirlpool accubake oven problem
Hi All,
I tired the delayed bake work around and it didn't help me.
So, being a trained scientist... I know just enough to be dangerous! Here's what I learned. (imitate me at your own risk. This thing is on a 220V circuit at 30A... you or someone else in your house could get badly killed if you do something wrong. You definitely want to send small children to the movies, or at least to bed before trying this!)
First, I turned the self-clean on for 60 seconds to see if both elemets were working. The broiler got bright red but the bake element didn't. The door unlocked as soon as I shut it off, so I could I touched an ice cube to a few insided parts to see how hot they were. The bottom of the oven was barely warm, but the baking element instantly melted and sizzled my ice cube.
Good enough for me: Both heating elements are working, so it must be a controller problem.
Next I turned the power off at circuit breaker, and double checked that the oven was dead. I pulled it out of the wall and removed the top sheet metal cover. Inside I found a red plastic envelope containing a "Tech Sheet". It has a schematic diagram, plus a table that explains the error codes and what to do about them. Be sure to read all the dire warnings and the bit about "For Service Technician's use only" before deciding that you are foolish enough to do anything with it. :-)
I undid and inspected the connector for the printed ribbon cable from the keypad to the controler circuit board. (I happen to know, being a scientist, that 90% of all problems in the universe are caused by bad contact) I didn't see anything obviously wrong, so I reassebled it carefully, making sure the ribbon was fully seated.
I then powered the thing up. It said PF for power failure. I pressed cancel for 5 seconds and it said F0E0 which means no pre-existing fault was detected.
I then pressed bake, and lo and behold the damn thing baked! :-)
I'm not certain it was bad contact, since the other 90% of the world's problems are caused by software. It's entirely possible that power cycling was this thing's idea of CTRL-ALT-DEL. Maybe someone can try flipping the breaker off for 10 minutes without taking anything apart, to see if that clears the problem?
I also have no idea how long this will stay fixed....
Has anyone tried calling Whirlpool? 1-866-698-2538, M-F, 8 am - 8 pm Local Market Time, Sat. 8:30 am - 5 pm Local Market Time, according to their website.
Stay tuned... if I'm not back, the thing is still baking... :-)
3answers
Re.probe and bake
I had the same problem and pulled off the contorl panel and removed the ribbion looking thing. You might have to do this a few times and wiggle it a little. It took me about 4 trys to get it to stop. also you can lock the control panel and the beeping will stop...this was my temp fix until I figured out how to get the control panel off and what to do.
Top Ovens Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you an Oven Expert? Answer questions, earn points and help others
