Cameras Logo
Question about FUJIFILM Cameras
Can someone tell me were i can find a driver disk for fujifilm ask2000
Posted by Angeler Hall on
  • FUJIFILM Master
  • 6,587 Answers
I don't know about a driver disk. You can download the legacy drivers for the ASK-2000 here: https://www.fujifilm.com/uk/en/business/photofinishing/downloads#legacysupport .
I hope this helps. Note: this probably doesn't include any third-party apps that came with the thermal photo printer. I can't find any software for the ASK-2000 outside of the UK support page.
Posted on Dec 01, 2022
How do you replace ask2000 printhead
Normally you can follow these given steps..It can be different for different model.....
Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place.
The print carriage will move to the center of the unit. After the print carriage stops, release the gray print carriage latch and lift upward to access the printheads.
Remove the old printhead by lifting the printhead handle and pulling upward.
Being careful to touch only the black plastic remove the new printhead from the packaging and gently remove the plastic tape.
Using the printhead handle, push the new printhead firmly down into the appropriate slot; matching the color on the top of the printhead to the color on the printhead carriage.
Move the print carriage latch down, and make sure the loops catch the hooks. Snap the latch into place, and close the print carriage access door.
After the message to align the printheads appears in the front panel display, press Enter . A page prints to confirm alignment.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
1helpful
I have a fujifilm s1000fd, but have no disk for the software, to download pictures on to pc, can I find software? I have found updates, but not orginal software, without cd's.
You don't need the software, only the driver. The driver can be downloaded here:
http://www.fujifilm.com/support/digital_cameras/software/#usbDrivers
Your camera is PTP compatible. After installing the driver the camera will appear in My Computer and you can access the images from there.
2helpful
2answers
I have fujifilm finepix s9600 and need the software to download photos. Can i download this from the net
when you connect your camera with the pc the camera will probably appear as a seperate drive on your computer. for example if you have a hard disk C: and a dvd driver named D: check to see if a new external disk appears as E: which will contain the folder of your pictures on your camera.
you can also check here
http://www.fujifilm.com/products/digital_cameras/s/finepix_s9600/index.html
4helpful
Fujifilm ask-4000
I have the driver disk if you need it.
Top FUJIFILM Cameras Experts
Steve
David Shaub
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
