Refrigerators Logo
Question about Kenmore Refrigerators
How do I install a garage kit in my Kenmore Hotspot side by side
My fridge freezes my food in the winter and I want to install a garage kit. How do I remove the control box?
Posted by Mary Kay Mutz on
2answers
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
If the fridge is in a garage, will the cold weather impact the operation of the unit (freezer stop freezing foods)?
yes the cold weather can effect the proper operation of the fridge they make a garge kit for these unit that can be baugh separatly and installed to help this problem
2helpful
Would like to put older side by side refrigerator in our garage. I was told in the winter, when it gets cold the freezer side will not keep foods frozen. I had an older top freezer refrigerator in the...
It could be a problem depending on how cold your garage gets in the winter. Most refrigerators depend on the compressor turning on to cool the freezer section and that cold air is used to cool the refrigerator section. If your the temperature in your garage gets in the 30-40 degree range in the winter. The compressor may not turn on sufficiently since the refrigerator is typically around the 35-40 degree range. This will cause the freezer to warm up to the fridge temperature and your freezer items will defrost.
1helpful
I recently had to throw away some questionable food that had partially thawed in the freezer cabinet of my kenmoore, model# 253.67882508 fridge with freezer on top. i keep this fridge in my garage and in...
probably,there is a garage kit available that willallow it to work at colder temps,listed in owners manule under accessories the thermostat senses refrig compartment temps.soif garage temp is below 40 or so the thermostat just doen't turn the unit on enough or not at all
2helpful
Refrigerator/freezer in garage doesn't keep food frozen in winter
Yes there is a solution. You need to install a garage Thermostat Heater. This will trick the thermostat into thinking it is in a warm environment. This article will tell you why this is happening and the solution as I described. Sorry but for some reason I cannot post this as a link. Copy & Paste into your browser. http://applianceparts.wordpress.com/2009/01/12/why-won’t-the-freezer-in-my-garage-refrigerator-freeze/
All food on top shelf of refrigeratr is freezing
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Freezer side works fridge side doesnt
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
    click on the required option.
Freezer doesn't freeze in winter?
Domestic refrigerators nowadays are designed not to operate at temperatures less than 45 degrees. First, if it's 45 degrees in the house, people probably are not living there. 2nd, 45 degrees keeps food refrigerated. 3, if people are not living in a space, then they don't need to keep frozen food.
This is a result of the changes in refrigerants we've been going through since 1992.
If you want an outdoor freezer, buy one, and make sure it's designed to be used in a non conditioned space.
7helpful
2answers
Does outside temperature affect performance of freezer
Top mount refrigerator installed in a garage and the food in the freezer is defrosting when
the temperature in the garage goes below 55 degrees fahrenheit.
On top mount refrigerators you cycle the compressor and fan/fans from the food
compartment temperature. When the room temperature gets colder than 55 F, you have
long off times waiting for the food compartment to warm enough to trip the cold control.
This long off time is allowing the freezer temperature to get high enough that food can start
to defrost.
There is a kit for refrigerators installed in applications where the temperature can go as low
as 34 F and still maintain good freezer temperatures. The kit part number is 5303918301
and it contains a heater that mounts in the control box and an instruction sheet advising
how to install the heater.
Kit 5303918301 contains:
Part # 5303950194 Instruction sheet
Part # 241532101 Heater
Top Kenmore Refrigerators Experts
vince
Dennis
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
