Microwave Ovens Logo
Question about Frigidaire Microwave Ovens
Frigidaire pleb27m9ecd built in oven/microwave. The oven works fine. The plug on the oven that microwave plugs into is not working.
Posted by Robert Augustyniak on
Eric Zhang
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 10 Answers
It sounds like you may have an issue with the plug that connects the microwave portion of your Frigidaire PLEB27M9ECD built-in oven/microwave to the electrical supply.
Here are a few things you can try:
  1. Check the power supply: Make sure that the oven/microwave is properly plugged into a working outlet and that the circuit breaker is not tripped.
  2. Inspect the plug: Look for any visible damage on the plug and make sure that the connections are secure.
  3. Check the wiring: Make sure that the wiring inside the oven/microwave is not damaged or loose.
  4. Test the outlet: Using a multimeter, test the outlet to see if it's providing power.
  5. Test the microwave: If you have access to a known good microwave, you can test the plug by plugging it into the known good microwave and see if it works.
If none of these solutions work, it's likely that there is an issue with the electronic control board or the plug itself, which will require professional repair.
It's best to contact the manufacturer or a professional technician for repair. They will be able to diagnose the issue more accurately and repair it.
Posted on Jan 18, 2023
MY microwave just stop working all of a sudden what can I do
-Have you try to plug it to different outlet to see possibly the outlet has no power. Or try different circuit to plug into the one the microwave plug in to see it work or not. If no work then there is not power at that outlet. The breaker is pop.
But if it works then you possibly need new microwave.
Good luck
Mai
Fuse location
Good Afternoon Friend, that's a great question!
Depending on the model of your Frigidaire microwave, the fuses are typically on located behind the control console, on the magnetron or on the oven capacity. However, if your microwave does not heat, you may possibly have a faulty control panel, magnetron, or experiencing an issue with the power supply. Please confirm that your microwave is plug into its own outlet and that you are not using a GFI outlet. Hope this helps! - Z
Sharp Carousel Microwave Mdl 1875 for our RV is dead
>> We also tried plugging our toaster into the microwave plug outlet, and the toaster wouldn't work in that outlet, but worked just fine in a different outlet in the RV.
This means the outlet you plug your microwave into needs to be fixed in addition to fixing the oven. Breaker? Fuse?
>> I understand from another RV forum that microwave ovens for RVs have "special circuitry and cooling features" not found in regular countertop ovens for household use.
Not really in my experience. Any microwave supplied with clean AC power and proper venting space will be fine.
But I'd bet your microwave can be fixed affordably.
The main internal things which can result in this model being dead (no display, no light when you open the door, no beep when you press a pad on the keypad) would be the 20A fuse and the magnetron temperature fuse. There could also be bad connections on the noise filter board.
Also, sometimes a power surge can cause the power to be interrupted to the low voltage transformer on the board, and I regularly repair those boards. I can also write a technical statement to your insurance company or to an RV park as needed.
At my Web site, I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The relevant service manuals for this model are here and here.
You can order Sharp parts from Sears or Encompass.
Contact me directly if you need more help.
- William E. Miller, AS-EET
[email protected]
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
I just bought a GE 1150 watt microwave. It worked fine in the store, but when we plugged it in at home, there is no power. The outlet works because I plugged a night light in and it lit up. Could the...
Hi, try the microwave in another outlet, if it works there then the first outlet is bad but if the microwave does not work in another outlet then the microwave is faulty and you need to take it back to the store and get another one as a replacement...
The microwave had been working fine we now have no power at all
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Top Frigidaire Microwave Ovens Experts
Marvin
Marvin
Jaime Hernandez
Steve
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
