Microwave Ovens Logo
Question about Emerson Microwave Ovens
Need owners manual for Emerson microwave oven MW8126W tried to put on defrost didn't work, now keypad not working. Please help.
Tried to put on defrost but would not work now keypad not working at all. Was working fine before I messed with it. Unplugged to reset did not work. Please help I need my microwave to work real bad today!!
Posted by Luzanne Craig on
ADMIN Andrew
    Top Expert:
  • Emerson Master
  • 53,374 Answers
No manual for that one, but the link might work better for you is you are outside Canada. The 8106 might be close enough. If you do a power reset, the power needs to be off for 5 minutes at the wall plug.
https://www.google.com/search?q=emerson+microwave+mw8126w+manual
Posted on Nov 26, 2022
Keeps going to def1
You have a shorted membrane keypad.
You can find links to helpful exploded view diagrams, part ordering help, and repair help here.
I recommend that you bookmark that link to your favorites.
I bought a used Emerson microwave from a neighbor moving out of the building. He did not have an Owner's Manual to give me. I'm trying to find one online but there are so many models that Emerson makes. Is...
The model that you show in the picture is the MW8107WA which has that model number right on the microwave just at the very bottom of the keypad. I'm guessing that you've already looked in the back of yours for a metal plate or sticker that lists your model number on it. Sometimes this information can be found where the door latch meets the door handle on the inside of the microwave.
The manual for the model you have pictured can be found on this very site.
It's here:
http://www.fixya.com/support/p113437-emerson_mw8107wa_1000_watts_microwave/manual-11318
The instructions are all pretty basic as far as preset buttons and setting the clock and whatnot and so they should pretty much apply to most of the microwaves that Emerson has available.
As far as the instructions regarding weight defrosting of meats and poultry that's usually trial and error anyway.
The best way I know of to see as many pictures of Emerson Microwaves as possible would be to put the words:
Emerson Microwaves
into Google and then click the link for "images" (found near the top upper left the page) instead of the "search" button.
That should bring up plenty of pictures of their microwaves.
When pushed, the 30 sec button says 3 minutes. none of the display buttons work.
Have you inadvertently programmed your microwave for "autostart"?
Your model microwave has the ability to be programmed to go on at any given time of the day/night, even when you're not home so that you can have a defrosted and cooked meal waiting for you when you get in.
I know that if you hit the 30 sec button or the minute button when your micro is programmed to autostart it will tell you the time that it's programmed to autostart or the amount of time that's left for it continue cooking.
Have you tried unplugging it for a few minutes?
This should clear it's memory and then all you'll have to do is set the time on the regular clock if you want.
Here's where you can download and read your owners manual for further instructions on how to use the autostart feature and everything else:
2helpful
2answers
I have an Emerson Microwave Oven MW8997W and cannot change the hour (time) on my clock. How do I change the clock? Debbie
If your keys do not work at all, you probably have a bad keypad, in which case I'd ask you to reply back. In the meantime:
SETTING THE CLOCK
When the microwave oven is plugged into an outlet,
the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been set,
the time will appear with blinking colon, unless
the oven is cooking or defrosting.
You can actually download your owner's manual here
We're happy to help and we appreciate your thoughtful rating of our answer.
Emerson microwave 900w
i believe majority of emerson got programmin ERROR intheir KEYPAD.. my emerson microwave got similar issue ..its a brand new one abt few monts old..it started actin weird way ..its keypad wont work..tried many thing unplug it pluge it back in everthing tht necessary..but still keypad is locked..no not the child procted locked..it locked with a digits 00.00 ...sometimes it work sometimes it dont...so no clue wat to do ...
1helpful
Emweson stainless 900 watts
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, then try again.
If it still doesn't work, it may have a bad keypad or a problem with the control circuit board.
Please write back with more details if you need further help.
5answers
Emerson mw8107wa user manual
This manual is available on FixYa, see link below: http://www.fixya.com/support/p113437-emerson_mw8107wa_1000_watts_microwave/manual-11318 Please update the question & let us know if the information given was useful to you - Good Luck!
I don't know how to use my automatic defrost.
http://www.fixya.com/support/p113437-emerson_mw8107wa_1000_watts_microwave/manual-11318/page-25 Here is the page of your owners manual that shows how to auto defrost. It is a bit hard to read. If you have your owners manual still, it is on page 24. Hope this helps.
Top Emerson Microwave Ovens Experts
David Shaub
Jaime Hernandez
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
