Washing Machines Logo
Our Bravos XL MVWB725BW0 started overflowing the fabric softener dispenser, because the water flow is way too high. The same thing, to a lesser degree, happens on the bleach dispenser not as much water, but still too much, and the detergent dispenser behaves properly not too much water. This started suddenly; we changed nothing.
Posted by Tom Sibert on
Fabric softener not dispensing. Water floods over the top and leaks out to floor
The dispenser should be removable. It uses syphon method to drain. Take it out and clean it.
Iwd71250uk fabric softener staying in dispenser.
Compartment 3: Additives (fabric softeners, etc.)
The fabric softener should not overflow the grid.
Cleaning the detergent dispenser drawer
Remove the dispenser by raising it and pulling it out (see figure below). Wash it under running water; this operation should be
repeated frequently.
25825864-ineink0kisfnom0atbkujjcx-3-10.jpg 25825864-ineink0kisfnom0atbkujjcx-3-3.jpg 25825864-ineink0kisfnom0atbkujjcx-3-6.jpg
Dado
1helpful
Front load washer dispenses fabric softener drawer fills water
either the auto dispenser is sticking , take out and clean with hot water. Or flow control valve needs replacing.
2helpful
How do I get the bleach dispenser to drain?
Hello Denise C - There are several things that could cause the bleach to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is bleach? If it is pure bleach, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the bleach dispenser with water. The bleach dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the bleach solenoid is energized and water flows into the bleach dispenser cup. When the cup is full the water siphons out and bleach and water flow into the tub.
If the liquid in the bleach dispenser is pure bleach you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the bleach solenoid and a volt meter is required.
If the liquid in the bleach dispenser is water you probably need to clean the dispenser cup. Scum will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the bleach and overflow the dispenser cup and run into the tub.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the bleach compartment. When the water level goes above the maximum line stop pouring. The water should all drain out. You may also test the fabric softener compartment the same way.
I do hope this information proves to be helpful.
10helpful
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
1helpful
Fabric Softener Dispenser Overflowing
Sounds like you have a blockage check/ clean remove dispenser to do
2helpful
2answers
The dispenser for fabric softener overflows all the time and does not go down.
Its clogged ... probably ... I have had success putting hot water down the hole ... but expect lots of spillage before it clears.
4helpful
Water left in fabric dispenser after load
The dispensers work by the siphon principle. You load the softener and at the proper time, the machine diverts water to the softener cup raising the level. In the softener cup, there is a tube loosely covered with a cap. When the level in the softener cup is raised high enough, a siphon effect is started and the softener is pulled from the cup into the washer. This will continue until the water quits flowing and air gets under tha cap, breaking the siphon. The amount of water remaining in the cup is dependent on the level of the cap, and the amount of residual water remaining in the dispenser fill tube once the siphon effect is broken. You can see this effect for yourself: take a measuring cup and slowly pour water into the softener cup, raising the level above the max line. When the level gets high enough, the contents of the cup will dispense. You can remove the cover cap that is a part of the dispenser and clean it; it will help. Removing the entire tray and cleaning all of the tubes and the cap assembly will also help. The only other thing that can be done is to change the dispensing supply valve, as it sounds like there may be some leak by after the fabric softener is dispensed. Having residual water isn't really hurting anything. It's only water, and the machine has dispensed the softener! Try the cleaning part first as this usually corrects the issue, and then the repair technician if it still bothers you. For as much as the extnded warranty costs, you should be completely satisfied with your machine.
Best regards, --W/D--
My Whirlpool calypso top loading washer poured water from underneath, water everywhere, what do I do and how do I do it?? No codes showed up. Thanks for any info. Rose
Sounds like the seals & gaskets have failed. If you removed the wash plate trying to unjam the washer and did not also replace the gasket kit, you may have violated the integrity of the water tight seals. However, sometimes also the fabric softener dispenser especially, gets clogged and may overflow and leak if the tubes are clogged with coagulated fabric softener. As I am writing this, my washer's fabric softener dispenser is clogged and the method I use to clear it has not worked this time - a cup of boiling water to melt the congealed fabric softener. One has to open the top lid (method varies by Calypso model - Whirlpool or Kenmore) to get to the dispenser tubing and reservoir underneath to get things flowing again, and in fact I have a small water leak on the floor where the dispenser overflowed a bit. That you have a leak, if it happens to come from such a clog, at least gives you a sign that your dispenser solenoids are not malfunctioning, requiring replacement of one of the circuit boards.
17helpful
2answers
Fabric Softener Won't Dispense
The fabric softener dispenser is notorious for clogging. Liquid fabric softener is essentially a liquid form of wax. After a period of time it begins to gunk up the inside of the fabric softener dispenser. If you remove the dispenser drawer and look into the cavity, there should be a series of holes in the upper part of the compartment where water sprays into all the dispenser trays. These holes get gunked up and clogged and water will not dispense properly. As a result, the washer goes through a complete cycle, but the dispenser stays full. If this is the case, you can take some cotton swabs and/or toothpicks and clean these holes real good. It may be a bit meticulous, but it should take care of the problem. Post back and let me know if this helps.
Top Washing Machines Experts
Marvin
Marvin
john h
