What error code is on Fisher and Paykel dishdrawer DD60DDFX9 flashing leds
Can anyone help me to decipher what error code is on my DD60DDFX9 with 'fast' led lit, 'lock' led flashing and all 3 wash modifier leds flashing 'extra dry', 'quick' and 'sanitize'?
Edit: got an answer from F&P: “ This is an F4 error - a heater fault.”
from what I'm seeing for the dishwasher, an E1 error means that the door is not properly closed. So, please look at the door of the machine to make sure that nothing is broken or that the dishwasher isn't too full. Thank you.
Fisher and Paykel Dishwasher Dishdrawer Error Code E5 = The first 3 program indicator lights are flashing. Error Code Cause: Water supply hose is crimped or bent. Drain hose is too low. Water tap not turned on. Not enough water supply pressure.
https://removeandreplace.com/2016/06/07/fisher-and-paykel-dishwasher-dishdrawer-error-codes-and-troubleshooting-how-to-fix/
Fisher and Paykel Dishwasher Dishdrawer Error Code E4 = Program indicator lights 1, 3, and 4 are flashing.
Error Code Cause: Drain hose is too high. Drain hose is kinked. The water is not draining out.
How To Fix: Check that drain hose is straight. Be sure the drain hose is connected per the installation instructions.
In order to find the availability of spare parts for your model of dishwasher it would be helpful if you can provide the Product Code from the label on the front of the main unit.
will need a description of the problem. Some of the common fault codes are F1, F2 and F3. All these fault codes stop the dishwasher and will not go away until the cause is removed. Please indicate the problem you are experiencing.
Your original problem, F4, was the machine trying to tell you that the heater plate was not working. When you turned the drawer up-side down, you may have damaged the wiring harness. If you do get a technician, call a fisher paykel authorized servicer, not an independent, and make sure you tell him about the F4 problem. A new problem has been introduced by the cleaning procedure, and both issues will need to be resolved.
