Washing Machines Logo
Question about Fisher and Paykel Washing Machines
Fisher and Paykel front loader grinding noise
Hello, Just recently out Fisher and Paykel front loader has started making a horrendous grinding grumbling noise and only appears at set times during the cycle. I assumed it was bearings on the drum or something caught in the machine but drum is free spinning and nothing caught in machine
Posted by Craig M on
My Fisher and Paykel washer is leaking water from bottom back right side in the rinse cycle. Any thoughts?
Question edited to correct name of maker, (Fisher PayPal :>)
Question moved to one of their categories.
No clue to whether a top loader or a front loader, which is why we ask for full 'make model (what it is)'.
If it is only in the rinse cycle, and if it is a front loader it is likely to be spray of a crack in the box that is the detergent drawer and fabric softener mixer. The only way to find out is to remove the top after a wash and look for where the water came from.
Some other ideas here
https://www.google.com/search?q=Fisher+and+Paykel+washer+is+leaking+water+from+bottom+back+right+side
My fisher and Paykel dryer just stopped working. All the lights come on but when I press the start button it just makes a light whirring noise.
Fraudulent page blocked for your protection http://www.worksite24.com/ Fraudulent pages usually attempt to trick you into sending money with the intent of obtaining unlawful gain.
1helpful
My washing machine will not start, just makes loud whirring noise and doesn't seem to be doing anything
IF this isn;t on target there are some good general washer troubleshooting videos on utube
Screeching noise during operation of machine
If it only screeches when the drain pump is running you can spray some crc or wd40 in to the bearing on the drain pump. That usually helps. You will have to turn power off at wall, tip machine back against a wall and get at the pump underneath on the right side at the front.
Top Loader Fisher & Paykel agitator makes banging noises when washing clothes
its common on these machines especially the bigger ones,chances are the suspension rods are worn out and need replacing
2helpful
Hello, My Fisher Paykel dryer is making a very loud motor noise when it is on Does this ring a bell??
The motor is going bad...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
1helpful
2answers
Noise in wash cycle
This is normal, because your washer will make sounds that you may not have heard from other washer.
1helpful
Dryer Problem
Grinding noise most likely due to the front drum bearings worn out - result is the metal drum making contact with the rim of the from panel.
This requires a total disassembly of the dryer to investigate & likely replacement of the front slipper pads (dry nylon slipper bearings 4 x ).
This will only be a succesful repair if you stopped using the dryer the moment it started screeching.
If you have let it run, the metal-on-metal will have gouged the edge of the drum and will rip up any new replacement bearing pads.
Do not attempt this unless you are a very competent handyperson. Many screws lost, cut fingers and swear words will ensure if you are not confident in approaching this job, so either toss the dryer or get a competent repairman to do the job.
Top Fisher and Paykel Washing Machines Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
