Televison & Video Logo
M
MARINA JANE MORAN Posted on Nov 23, 2022
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I get picture as well as sound on ewtn when it in on locked on the clearview box
I can get sound but not pictures for my satellite transmitted pictures for EWTN on television as on the clearview box it is on locked How do I get the clearview box off locked
R SHOAIB
Level 3:
Master:
  • Master 567 Answers
  • Posted on Feb 26, 2023
R SHOAIB
Master
Level 3:
Master:
Answers
567
Questions
0
Helped
80870
Points
1019
To unlock the Clearview box, you will need to locate the remote control for the box. Look for a button or key labeled "Lock" or "Parental Control" and press it to disable the lock. If you are unable to find the remote control, check the box itself for a physical lock switch or button.
Once the box is unlocked, you should be able to access the EWTN channel and get both picture and sound. If you are still having issues with the picture, make sure that the television is on the correct input or channel for the Clearview box. You may also want to check the cable connections between the box and the television to ensure they are secure.
I get the sound but not the picture because green lite is shining on locked I have satellite to get EWN How do I get the picture and sound together for ewtn
It sounds like your TV may be set to a channel that is locked or not available through your satellite subscription, which is why you can hear the sound but not see the picture. Here are some steps you can try to get the picture and sound together for EWTN:
  1. Check your satellite subscription: Make sure that your satellite subscription includes EWTN. You can check your subscription package or contact your satellite provider to confirm.
  2. Check your TV channel: Make sure that you have selected the correct channel for EWTN on your TV. You can refer to the channel guide that came with your satellite subscription or check online for the correct channel number.
  3. Check for parental controls or channel locks: Your TV may have parental controls or channel locks that are preventing you from accessing EWTN. Check your TV settings or parental control settings to make sure that EWTN is not blocked.
  4. Check your cable connections: Make sure that your TV is properly connected to your satellite receiver and that the cables are securely plugged in. You can also try unplugging and reconnecting the cables to make sure there is a secure connection.
If you have tried these steps and are still not able to get the picture and sound together for EWTN, you can contact your satellite provider for further assistance.
I HAVE SOUND AND CABLE CANNEL BUT NO PICTURE. IS THERE A RESET FOR THE PICTURE. THE TV IS A 2010 SANYO 42" MODEL DP42840
Are you on cable or satellite? You'll need to reset the receiver box, not the TV, and if that doesn't work, call your cable or satellite service.
My picture and keep on breaking up on some channel
If you have a good picture on some channels and the picture breaks up on others , it could be the input signal. What is the source of the input signal; i.e. cable, satellite, antenna???? Do you have a cable box? The problem may be with the box or with the provider's signal.
SOUND NO PICTURE
have you been watching through cable program or coming from a satellite box.tried with reset the cable box.
I NEED SONY BRAVIA T32 FULL MANUAL...how to conect to computer and camera
Hello there,
Here is the link to the full manual:
http://support.sony-asia.com.edgesuite.net/consumer/IM/4110401121.pdf
Before connecting your devices...
The signals that enter the TV and connected devices will need to be output in the correct format using the suitable connections. Below are the different types of video connectors. When connecting the TV, use the inputs that are available on your devices that provide the best video performance.
Video performance level Name Aspect Signal transmitted Separate audio connection required arrw.jpg HDMI cnn_hdmi.jpg Picture + Sound No DVI*1 cnn_dvi.jpg Picture Yes
L-AUDIO-R Component video cnn_component.jpg Picture S-Video cnn_s_video.jpg Picture Composite video cnn_composite.jpg Picture RF/Coaxial cnn_coaxial.jpg Picture + Sound No
*1 If the equipment has a DVI jack and not an HDMI jack, connect the DVI jack to the HDMI IN (with HDMI-to-DVI cable and/or adapter jack), and connect the audio jack to the AUDIO IN (L/R) jacks of HDMI IN. (The DVI connector is for video signals only) To enjoy the best visual experience with your system, it is preferable to connect your best devices with the highest quality connections available. For example: your Blu-Ray Disc player or HD Set Top Box with HDMI, followed by your DVD player with Component, then your Video Cassette Recorder with S-video etc.Note: The quality of the picture also strongly depends on the quality of the cable used.
HDMI The High-Definition Multimedia Interface (HDMI) is an all-digital audio/video interface capable of transmitting high definition video and audio signals. HDMI provides an interface between any compatible digital audio/video source, such as a set-top box, a DVD player, a PC, a video game system, or an AV receiver and a compatible digital audio and/or video monitor, such as a digital television (DTV). DVI The Digital Visual Interface is capable of transmitting high definition video, but does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA). It is possible to connect an HDMI device to a DVI device using a HDMI to DVI adapter. Component video Component video is an analogue connection. It is capable of transmitting high definition signals. Component does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA) S-Video Separate video, abbreviated S-Video and also known as Y/C is an analogue video signal that carries the video data as two separate signals (brightness and colour), unlike composite video which carries the entire set of signals in one signal line. S-Video, as most commonly implemented, carries standard definition video. It does not carry audio on the same cable. Composite video Composite video is an analogue video (no sound) format. This is the connector you should use if you do not have any other connector available, in terms of quality. RF/Coaxial RF Coaxial Cable connection is used for transferring television signals (audio and video) originating from an antenna or cable box to a Television.
Hope this was helpful to you.
Goodluck
Elect_Comp
The picture freezes and the sound is lost. Until the picture returns and the sound returns,this happens every couple of seconds.
If you actually have the Zenith model TV (B25A24Z), the trouble is not in your set. This model has only an analog tuner, and what it sounds like you are describing is digital pixellation. This is what happens with a digital-to-analog converter box when it gets a weak signal, with rain fade or heavy snow on a satellite dish antenna, or when a digital cable system has some signal problems. The converter equipment locks the last complete frame (or breaks up into blocks and freezes) and the sound is muted.
You'll need to look for the cause of your trouble in whatever is feeding the TV. If you have a digital converter box for off-the-air broadcasts, make sure you have a good antenna and all the connections are tight. If you have satellite TV service or digital cable service, you might need to contact your service provider for help in troubleshooting and fixing the trouble.
Doesn't have a picture or sound when TV is turned on
what type of equipment do you have? do you have satellite or cable? check cabling, make sure tv and satellite box are on (if you have satellite box), cabling could be bad try replacing with other cabling
Free to air satellite picture but no sound
Hi...
Does the satellite box have left/right audio outputs?
If so, try connecting them to the red and white Video or DVD inputs in the rear of your audio receiver
I have a sony bravia kdl-26m4000
Cable boxes have notoriously flaky HDMI outputs. I have seen No pic and no sound with their HDMI outputs as well as a host of other problems. You can try getting the cable box replaced; unfortunately I have seen multiple cable box replacements not fix the problem. The best solution is to leave the component cables connected; you're not losing hardly any resolution/picture quality by using the component instead of the HDMI. Solution #2: switch to a satellite provider. I rarely see HDMI problems with satellite boxes
No picture
sounds like an audio/video connection problem. If you have a cable or satellite box connected with rca wires (yellow, red, white), check that the yellow wire which gives you picture is connected. the red and white are for sound.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
