Hello, I have a Saeco HD8772 automatic espresso machine and I recently replaced the grinder full assembly including motor etc. with a factory part. Since replacing the grinder, I have a new problem. Most of the time, the machine works well. But around every 3rd or 4th shot, the grinder grinds the beans and then throws up an error and ejects the grinds. It then shows me the screen indicating that I need to add beans. This happens when the beans are clearly full. I suspect it has something to do with the automatic dosing system, where it monitors the pulses from the grinder's hall effect sensors and the motor current, but I can't figure out what's wrong. I've tried the service menu and I can see the grinder revolutions counting up without issue. I've reset the unit to factory default settings in an attempt to clear and settings from the dosing system. I've tried adjusting the grind, from fine to coarse. Nothing seems to be fixing the issue. If anyone has any suggestions, I would really appreciate it!
This particular make turn up on Fixya about 3 times a week. They are very unreliable and can only be fixed by dealers throwing parts at them. Take it in for service.
since you've replaced parts and performed factory reset, then I would suggest taking the device in for repair through Home Depot or Geeksquad/best buy or replacing with a new Espresso machine.
Thank you.
