Question about Yamaha Audio Players & Recorders
My Yamaha emx5000-12 has no input from all channels
Posted by shavarn young on
ADMIN Andrew
    Top Expert:
  • Yamaha Master
  • 55,679 Answers
Posted on Nov 22, 2022
2answers
No center channel sound on my Yamaha receiver
Is the center channel amp blown? How about checking the center channel input wire for signal?
Yamaha AX700 amp distorts R channel - sound suddenly louder from R LS and distorted or metallic. Swapped LS L to R to eliminate
1) Check speaker polarity carefully
2) Ensure that speakers are securely connected.
3) Check your Balance control
4) Check your inputs (change inputs L/R)
If that does not alter or fix the problem your right channel may have developed an internal fault. Repair or have it repaired.
Have Fun
My Yamaha MG102C has no sound, and all of the LED's are on. There's no inputs connected at all.
Correct me if I'm wrong, but if you have nothing connected as an input, you're NOT going to hear anything. I assume you can't get your inputs to get to main output fader(s), if that being the case, first make sure your gain knobs are up at about 12 o'clock position, your channel faders are up to 0 and then make sure "channel assignment buttons" are assigned to stereo outputs.
2answers
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
3answers
Yamaha RX-550 receiver. Presently, no sound on left speaker channel. Previously, no sound on right speaker channel could be cleared by rotating the Input nob.
were you able to solve this one ? I have the same problem with mine. The only way to clear the lack of sound in one of the speakers is to rotate the input knob !!
No stereo signal out from yamaha p 2500 s
It's unclear what type of connectors are on the end of the cables(s) coming from your computer.
This amp only works with mono 1/4" TRS and XLR connectors, not standard RCA connectors.
Did you try the Right one in the Left Channel to see if the Left Channel worked?
Refer to the following manual and read up on the connectors (page 7) and the use of the Stereo/Parallel/Bridge Switch (page 8). When it is NOT in Stereo Mode the unit only uses the Right Channel controls and input.
http://img3.musiciansfriend.com/dbase/pdf/man/m_480824.pdf
STEREO/PARALLEL/BRIDGE switch
Use this switch to select the operating mode.
• STEREO mode
Channels A and B operate independently (as with a conventional
stereo amplifier). The Channel A input goes to the Channel
A output jacks, and the Channel B input goes to the
Channel B output jacks.
• PARALLEL mode
The Channel A input signal is output through both the Channel
A and Channel B output jacks. The Channel B input jacks do
not function. Channel A and B volumes can be independently
adjusted.
• BRIDGE mode
The Channel A input signal is output from the BRIDGE output
jacks. To adjust the volume, you must use the Channel A volume
control knob.
1helpful
Yamaha Mg12-4fx 12-Channel Mixer
ok look here on page 21 & 22 of 32 http://www2.yamaha.co.jp/manual/pdf/pa/english/mixers/mg12_4fxe.pdf
section #5," ST output"
the "st out" will go to the amp you have for the mixed sounds
section #1, "line or mic input"
this is the input for the guitar or a mic , but only one(mic or line ) per input # at a time
2helpful
Bad main right channel ( no out put at all )
I had the same issue with this same receiver. Unfortunately this is a known problem with this receiver and Yamaha knows about it. The usual fix is to have the input RCA connections in the back replaced to some updated ones. What has happened is that there is a shirt created using the current RCA input jacks and it is actually turning the internal amplifier off to that particular channel or channels. My local stereo shop ( who is a Yamaha authorized service center) knew about this and replaced mine to the tune of $200.00. Good luck
Yamaha RX-V757 No Left Channel Output - Video Sources Only
First - make sure it is not a defective cable by reversing the leads/colors on the inputs if problem then goes to the right channel then you know it is a bad cable/RCA, etc., connector. I would try that first.
Thanks,
dthomas
Left from speaker not working- Yamaha HTR-5940-6.1 channel
Redbird,
What do you have in the "multi channel input" jacks on the rear of the receiver? Those inputs Right, Left, Center, Surround R+L, and Sub are used when selecting 6 channel mode. They bypass the receivers surround processor board.
John W
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
