Hi sense tv. I only had it about 2 months . It worked ok when I got it. The power went out for a few hours one day. I don't know if that has anything to do with it. I use the sleep timer every night.
When you press the Power/Sleep button the radio turns on and displays a
number 90, or some other numbers. This is the play time that the radio
will stay on then turns itself off. It could be that yours is configured
with a sleep timer set to 01 minute, 10 or 15. You need to set the
timer for a longer period. Thus we turn it on by pressing the
Power/Sleep button, read the timer length then press again. Keep making
short presses: The timer will cycle through all preset sleep timer
durations. Select the length you want.
Hello
Canceling the Sleep Timer:
1. Press SLEEP to display the on-screen message.
2. Press SLEEP repeatedly until OFF is displayed.
Note: After 5 seconds of inactivity, the message box disappears
OK.
The TV is in 'showroom mode'. To fix: Click: Menu --> Picture --> Mode --> Power up then select: Home. Then click menu until you exit the settings. You will now be able to use the sleep timer.
If you unplug the unit for an hour or overnight, it should go out of sleep mode. If this dosent work then its not in sleep mode and the set has a problem in the power supply or the sweep circuit. Sorry you should seek a pro to assist you in this repair. Good Luck
