Question about The Office Equipment & Supplies
Fix display lines justification on Aastra M5316? It’s so left justified that first bit of info is cut off.
I can set the time and date but can only see the last digit of the year and time when I'm done. Only the last few digits of phone numbers calling will show in Call Display. It seems that everything is justified too far left.
R SHOAIB
    Master:
  • 567 Answers
To adjust the display lines justification on an Aastra M5316 phone, you can follow these steps:
  1. Press the "Menu" key on the phone.
  2. Use the arrow keys to scroll to the "Contrast" option and press the "Select" key.
  3. Use the arrow keys to adjust the contrast of the display until the lines are fully visible.
  4. Press the "Next" key to scroll to the "Line Justify" option and press the "Select" key.
  5. Use the arrow keys to adjust the line justification until the lines are properly centered on the display.
  6. Press the "Save" key to save your changes and exit the menu.
If you continue to have issues with the display lines justification on your Aastra M5316 phone, you may want to try resetting the phone to its default settings. To do this, press the "Options" key on the phone, then scroll to "Reset Phone" and press the "Select" key. Confirm that you want to reset the phone and it should revert to its default settings, including the default display line justification.
If the issue persists after resetting the phone, it may be a hardware issue and you may need to contact Aastra customer support or a qualified technician for further assistance.
Posted on Feb 26, 2023
1helpful
Trying to change the number of rings before my phone goes to Voice Mail on the Meridian (Nortel) M5316. Only two rings currently so I miss a lot of calls. Thanks!
Depending what system your provider is using it can either be done by you at home or they will have to set it. If you call your provider they will help you or they will fix it. Each ring is set at 6 second intervals so if you have 3rings that is 18 seconds. If you was 6 rings then ask for 36 seconds etc. hope this helps
I have a Meridian M5316 and the there is an existing voicemail on the phone how do I change the voicemail without knowing the current password?
Your provider will have to reset it for you. Phone them and ask for a reset. They may charge you a dollar or so. But that is the only way
How do I change the date and time on my Meridian Business Set M5316?
To Change the Date and Time:
  1. Press
  2. Press the volume key until "Time and Date Set?" is shown on the display
  3. Press
  4. Enter the date using the format shown on the display (DDMMYY)
  5. Enter the current time based on the 24-hour clock
  6. Press to save the new time and date settings
  7. Press or to exit the programming mode
To Change the Display Fomat:
  1. Press
  2. Press the volume key until "Time and Date Format?" is shown on the display
  3. Press
  4. Press the volume key until the desired format is shown on the display
  5. Press to save the new setting
  6. Press or to exit the programming mode
Nov 16, 2010 • Cell Phones
What is the importance of right align button in microsoft excel?
broken0196,
The right-align format is best for viewing numbers.
It is especially easier to read 'accounting' numbers where the decimals line up.
Generally, left-justifed is best for non-number alpha characters/words.
Center-justify is best (maybe) for column headings, etc.
I hope this helps you.
I've lost my user manual and I need to reset the date and time.
I lost a user manual, then found this site called find my manual. They emailed it to me in about 2 hours and it only cost about £3, which i thought was very reasonable.
http://findmymanual.com/
Hope this helps.
Jane
12helpful
2answers
Need to adjust date and time on screen.
Just above the Hold button, with the Aastra name display, that is a sliding piece that will uncover your setup menu button. Press that and navigate to time/date settings.
Hope this was helpfull.
I have had Quickverse 2005 for some time and used it with Microsoft word 2003. The cut and past worked fine. I have upgraded the same computer to Microsoft 2007 and, when I cut and past, the line spacing...
Thanks to the folks at Microsoft for setting that as default in 2007.
Go to the home ribbon, you should see in the heading styles, a style called normal. Right click on it and select modify.
Here you can select the defaults for the normal template which is used each time Word starts. You can choose your default font, size, etc. Underneath the font you have four sections. The first one is the justification which should usually be left justified. The 2nd one is important, this is your single-double-triple spacing icon. Select the first one. The next one after that helps to fine tune that a little bit. Click the two arrows point towards each other until the spacing doesn't get any smaller. Make sure that you select New documents based on this template, then click OK. If you have any further questions, let me know and I can assist further. Also, if you could please give this solution a rating of fixya, I'd greatly appreciate it. Thanks and God bless!
2helpful
Need manual
If you haven't received an answer to your request, You can find the manual at the following url:
http://www.florenceinc.com/en/documentation.php
If it doesn't take you right to the correct page, enter M5316 in the search window and it should find it for you. I tried to upload the document but there was no way to do it. Hope this helps.
Aastra 9110 Single Line Corded
Press the setup key and use the down,up,across arrows on the upper of the set below the window to find the date and time. Let me know if you get it done.
Do I need a network?
If that model phone has a rj14 jack ( standard phone jack) and when you plug it into a known good wall jack and you can draw dial tone then it will work. If not it requires a KSU to interface with the lines and that's a lot more equipment than you need for 1 or 2 lines. Thank you. Jer
Top The Office Equipment & Supplies Experts
vince
old marine
old marine
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
