Question about Swingline Office Equipment & Supplies
Swingline Model 747xx Spring Replacement.
Can the customer replace (purchase) and install the spring themselves? Doesn't seem to be removeable.
Posted by Venus Jaworski on
Steve Pack
  • Swingline Master
  • 6,100 Answers
No one sells parts for this stapler, unfortunately it is disposable.
Posted on Nov 18, 2022
How do I replace the spring on a Swingline electric staple gun model 34201
Unlikely you can. Contact them direct.
Contact Us ' Swingline
www.swingline.com > contact-us
Desktop Staplers · Electric Staplers · Heavy Duty & Specialty · Mini Staplers · Stapling Accessories · Punches · Manual Punches · Electric Punches · Heavy Duty ...
How do I replace the compression spring on a Makita LS1030 saw? I have the older version with the straight handle, not the "D" handle.
Dear Leonard,
I see that the Makita LS1030 does have a different compression spring mount than the newer "D" handle models. There is a parts schematic of your saw with the straight handle at http://www.ereplacementparts.com/makita-ls1030-miter-saw-parts-c-97_98_99_322.html. Perhaps this will aid you in puzzling out the disassembly and repair of your compression spring. So you know, it appears that the primary compression spring for your exact model is now considered obsolete and is unavailable on most parts replacement websites.
If if your problem is just that the spring is weak, a local machine shop may be able to tell you if the spring can be re-stretched to return it to its new compression level.
Makita is known for their excellent customer service, and if you call the parts/repair division of the company (Contact info located on Makita website) the technicians may be able to not only coach you through the spring replacement process. You should also ask if the spring on a newer LS1030 series is interchangeable or if Makita themselves have any NOS springs for your saw in stock.
Good luck in your search,
E Bishop,
Sep 29, 2014 • Saws
1helpful
2answers
How do I repair this stapler as the small spring came off?
if the spring still with you its okay if not try find new one then, please find similar stapler examine it and follow how it fix up, if i write it would be difficult to explain and understand..
4helpful
2answers
Swingline electric staple gun owners manual model #34201
spring inside where staples are loaded detached how do I reconnect it to proper position
11helpful
Instructions on how to load a swingline heavy duty stapler.
You pull up and back on the stapler head. Then pull out the spring that keeps the staples loaded. Be careful as the spring is very strong. Then put in the staples and put the spring back in behind the staples.
1helpful
Spring on my Swingline POWER GUN 1000 is broken.
Junk it, peice of ****!!!!! Extra heavy duty and the spring is effin junk, throw it out!!!
Top Swingline Office Equipment & Supplies Experts
Paul Bade
Arnie Burke
Arnie Burke
Marvin
Marvin
Are you a Swingline Office Equipment and Supply Expert? Answer questions, earn points and help others
