Dryers Logo
S
Samuel Posted on Nov 17, 2022
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Logik LVD7W18 Tumble-dryer making a knocking sound
My tumble-dryer is making a knocking sound when rotating. I have attempted to remove shell and see if there is anything loose but seemingly okay. The knocking noise even occurs when drum is empty and it pushed by hand. Help!
Roger R
Level 3:
  • Master 2,005 Answers
  • Posted on Nov 18, 2022
Roger R
Master
Level 3:
Answers
2005
Questions
0
Helped
163520
Points
6473
One might need to oil up some of the internal parts of the dryer that are not electronic. It sounds like there might be friction causing the nocking sound. After the oiling of metal portions of the dryer, the sound should go away.
Thank you.
  • ADMIN Andrew
    ADMIN Andrew Nov 18, 2022
    You might be learning the Roger? Still working through your answers, and only 4 gone so far, but 16 to go :>)
Logik 8kg heat pump tumble dryer error message unknown
I think it is a play on words and heat pump means it pumps heat. A heat pump in normal parlance is taking heat from a source that would be wasted, like turning a refrigeration system around and using the heat supplied from cooling, to heat an area.
https://www.currys.co.uk/products/logik-lhp8w18-8-kg-heat-pump-tumble-dryer-white-10174302.html
I would guess it has an element, and when you look at the wider view, it is a condensing dryer so the heat from the element makes steam from the clothes which is condensed by the incoming cold air, ergo, it is a heat pump.
https://www.google.com/search?q=Logik+8kg+heat+pump+tumble+dryer+heat+pump
Get your old multimeter and screwdriver out and start testing.
Dec 05, 2022 • Dryers
I have a logik lvd715 tumble dryer and it doesn't do anything except sit there with all the res led lights on, can't even turn it off HELP
sadly we do not know all makes of dryers here ,suggest you call a local repair service that can come test it and make needed repairs
Jun 02, 2021 • Dryers
1helpful
Logik tumble dryer gdz 60-10sw heard clanging noise now dryer still goes on but drum doesn,t turn.
Sounds like the drum has fallen off of the support rollers. Will need to open up cabinet to verify
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jul 04, 2016 • Dryers
2answers
Hotpoint vtd20 tumble dryer is making a horrible grinding/grating noise when the drum is rotating and seems worse in 1 direction any ideas??
We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair Need help fixing your appliances
Jan 02, 2011 • Dryers
The dryer will not tumble. It makes sound when
Replace your broken belt. Pop the top (spring loaded). and remove the front for access.
Jan 02, 2010 • Dryers
2answers
Tumble dryer drum won't turn
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 06, 2009 • Dryers
2helpful
Maytag dryer won't rotate after blower wheel replacement
Check the drive belt and belt tensioner. From the way you describe it, the belt is loose and with a load in the drum, it will not rotate due to belt slipping.
5helpful
Whirlpool Ultimate care ii Dryer wont tumble
If your dryer doesn't tumble, check these:
Belt,
Motor,
Door switch.
Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
Remove the belt,
Check for obstructions in the blower fan housing,
Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
Go here to see a diagram for your model:
one of two types. "H" or "J"
http://www.repairclinic.com/0079.asp#DiagramH
1helpful
Condensing tumble dryer not running
has the belt shredded and wrapped itself around the shaft? try to manually rotate the drum to see if the belt is free and the motor shaft moves. it sounds like the motor is stuck and the smell is the uncirculated heat at the back. let me know your results.
taking the lid off will gain access.
Feb 16, 2008 • Dryers
Top Dryers Experts
john h
