I can make it spin by manually setting it to spin, but it does not rinse the soap out.
The dial only turns in one direction. Let’s start from the beginning. Does the washer work normal at the start of the wash load?
please rotate your cycle dial in the opposite direction of its usual motion by 90 degrees (probably counter clockwise). Then you can run the cycle again and the drain/spin/rinse should work. Otherwise, please power cycle your washing machine.
Thank you.
