Master
- Posted on Feb 26, 2023
Re: When i turn the Magnavox infrared heater on shortly...
If your Magnavox infrared heater is turning off and blowing cool air, it could be due to a few different reasons. Here are a few troubleshooting steps you can try:
- Check the thermostat: Make sure the thermostat is set to a temperature that is higher than the current room temperature. If the thermostat is set too low, the heater may turn off because it has reached the desired temperature.
- Clean the filter: If the heater has a filter, it may be clogged with dust and debris. This can restrict airflow and cause the heater to overheat and shut off. Clean or replace the filter according to the manufacturer's instructions.
- Check the power source: Ensure that the heater is properly plugged in and that the outlet is functioning correctly. If the outlet is faulty, try plugging the heater into a different outlet.
- Reset the heater: Unplug the heater for a few minutes, then plug it back in and try turning it on again. This can sometimes reset the heater and resolve any issues.
If none of these troubleshooting steps work, it may be a more serious issue with the heater that requires professional repair or replacement.
