Cameras Logo
Question about Canon Cameras
I have a Canon ISUS 177 Camera - help please with symbols
There is a symbol of 2 stars and a crescent in the top right hand corner of the of the screen with a lightning symbol underneath, which I cannot get rid of. The camera won't take a normal photo now as it seems to be on delay... ...Any ideas please?
Roger R
  • Canon Master
  • 1,599 Answers
The symbol with the moon/stars should relate to taking night-time pictures. The lightening symbol stands for flash (ie light shown when photo is taken). The delay should be due to the flash taking time to charge up prior to the photo.
Thank you.
Posted on Nov 16, 2022
ADMIN Andrew
    Top Expert:
  • Canon Master
  • 52,955 Answers
1helpful
Canon eos d40 makes a long noise before it takes a picture
It sounds as though you have activated one of the timers. On the LCD display on top of the camera look in the bottom right-hand corner of the display and see if there is a symbol that looks a bit like a one-handed clock (the timer symbol). If so, press the AF-Drive button on top of the camera and rotate the large, circular selector dial on the back of the camera until that symbol goes away. Now the camera should shoot normally.
4helpful
2answers
My camera won't flash no matter how many new batteries I put in it. It will take pictures that don't require a flash. I've reset everything twice and nothing has worked. Contacts are clean. ...
Some Canon cameras use some of the screws around the perimeter of the camera to serve as a safety switch to prevent activation of the flash if the case is opened. See this article for more info.
2answers
5helpful
How do you turn off the flash on a canon a630 camera
Press the button at the back of the camera designated with a lightning symbol. When you pressed it once, it will give you an option for lightning bolt which means flash ON and to turn it off, select the lightning bold with line through it.
3helpful
Turn off flash
With the camera ready to shoot in Auto mode - you will see a little lightening symbol in the top right hand corner of the screen. This indicates the flash is turned on.
On the left side of the circular dial at the back of the camera you will see a similar little lightening symbol indented into the dial. Simply press on this side of the dial to turn the flash on or off as you desire.
The symbol on the screen will go off when you push this to indicate flash is off and return if you press again to turn it on.
Thanks for using FixYa.
2answers
Flash
On your camera, there should be a button with a lightning bolt with an arrow at the bottom. This is the flash control. Push it until the lightning bolt symbol on the screen is crossed out, this means the flash is turned off.
You can look at the manual here:
http://www.mediacollege.com/equipment/manual/canon/camera/powershot-a75.pdf
The flash instructions are on page 42 of the manual, which is page 44 of the PDF file.
Switch off flash
You can't turn it off in auto. But in any mode other than auto, press the button with the lightning bolt on the back of your camera until you the lightning bolt symbol with a slash through it on your screen.
The user manual for your camera can be downloaded free from Canon's website here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=320&modelid=12914
G9 flash
In your display, is the small lightning symbol appear on the screen? Try cycling through the various flash options by pressing the "flash" lightning symbol to the right of the monitor. If the flash is set to flash when there's not enough light at the G9's descretion (with an "A" next to the symbol) then the flash may or may not go off. I oftentimes set the flash to go off all the time if the camera is not doing it automatically (with the A next to the symbol). Being in Auto mode versus the other preset exposure modes affect the flash options available too.
Won't take a picture
I work on these cameras all the time you have a ccd going out or has gone out that is causing the auto sensing feature to now work their for the camera stops working. 1 other thing it might be could be the main-board but they don't go out as often.
Symbol of a blank battery
You may have to manually rewind the film that you just loaded and try again. The is a manual rewind button on this camera. Before you load the new roll, check the condition of the shutter curtains/blades. Do they look out of place or pushed in?
Top Canon Cameras Experts
old marine
old marine
David Shaub
shadow
Are you a Canon Camera Expert? Answer questions, earn points and help others
