Dryers Logo
Question about Kenmore Dryers
I have a Kenmore Elite HE3 electric dryer that won't come on.
All the instrument panel lights come on. But when I push all the cycle setting and press start button, I get an error reading of Sensing/Revising Est. Time. It will not run or anything after that. I also sometimes get a reading on the door indicator of check Lint screen. I open the door and check screen to make sure it is clean, shut the door and the check lint scree light goes out. I press start and machine won't run, Still get error reading of Sensing/Revising Est. Time
R SHOAIB
    Master:
  • 567 Answers
The error message you are seeing on your Kenmore Elite HE3 dryer could be caused by a few different things. Here are some troubleshooting steps you can try:
  1. Check the power supply: Make sure the dryer is properly plugged in and that the circuit breaker or fuse is not tripped or blown.
  2. Check the door switch: If the door switch is faulty, the dryer may not start. Check that the door switch is engaging properly when the door is closed.
  3. Check the thermal fuse: The thermal fuse is a safety feature that can cause the dryer to not start if it is blown. Check the thermal fuse for continuity with a multimeter.
  4. Check the belt switch: If the belt switch is faulty, the dryer may not start. Check that the belt switch is engaging properly when the belt is in place.
  5. Check the moisture sensor bars: The moisture sensor bars can become coated with fabric softener residue, causing the dryer to stop mid-cycle. Clean the bars with rubbing alcohol and a clean cloth.
  6. Check the control board: If none of the above steps work, the control board may be faulty and need to be replaced.
If you are unsure how to perform any of these steps, it may be best to contact a professional appliance repair technician.
Posted on Feb 26, 2023
We just replaced the power cord and outlet for a Kenmore Elite HE3 dryer and now it will not go on. I flipped the circuit breaker on and it said PF and now I get nothing.
PF error = Power Failure - error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Here is a site to double check the wiring:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
Good Luck Tim
How do i light the pilot of my dryer
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
1helpful
Kenmore Elite He3 dryer..fine on timed but leaves cloths wet auto
find the metal sensors in the drum
scratchem up with sand paper
especially if you wash rugs, sneakers , or anything with acyrlic
1helpful
My kenmore elite he3 electric dryer control panel is not working. When the door is open the light inside is on, but with the door open or closed the control panel above does not turn on or light in any...
The control board is bad. You will have to replace it. You might aslo theck the fuse, sometimes they look a little different than you are used to. Refer to your owners manual and wiring diagram to find it. You can also find more info on the Whirlpool website. Whirlpool makes Kenmore.
1helpful
Dryer working but no heat
The manual says that two circuit breakers used,and that the dryer
can spin but no heat if one of them tripped, check your panel and see
if any breakers are tripped. If this was the problem,have an electrician
check the circuit.
7helpful
Kenmore Elite HE3 Dryer clothes not dry after cycle
it sounds like a clog in vent.if yours vents up thru roof you may need to have a chimney sweep come out and sweep vent.check and make sure the vent hose is net kinked or full of lint.
I have a Kenmore Elite HE3 dryer that somehow says the panel is locked. How do I unlock it?
look closely at the panel there is a button marked "control lock" press and hold it for 3 secs
1helpful
Kenmore Elite HE3 Dryer (3 yrs. old)
when u push the buttons do all lights light up if so ,, machine is in lock mode ,, press and hold the little icon that read lock for about 3 seconds unitll lights are off then run ,, let see
Open Questions:
Top Kenmore Dryers Experts
Marvin
Marvin
Mike
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
