Pramac p6000s generator yanmar engine etc not giving power out Readings at the plugs 113v on all plugs even on 110v and 230v Small display is showing correct voltage when flick between 110v and 230v on the toggle switch but nothing will work when plugged in They Did not have capacitor tester with them but visually looks good Continuity between the 2 capacitor exciter wires Continuity and out put from the stator windings and no continuity between them and earth Engine runs fine and still nothing works if increases rpm Any advice on this please thanks
Based on the information provided, it seems that the generator is producing voltage but not delivering it to the connected devices. Here are a few troubleshooting steps you can try:
If none of these steps resolve the issue, you may need to consult with a qualified technician to diagnose and fix the problem.
