Home Logo
Sean Malone Posted on Nov 11, 2022
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I turn the hands of a ship clock backwards to reset the time?
Roger R
Level 3:
  • Master 2,005 Answers
  • Posted on Nov 12, 2022
Roger R
Master
Level 3:
Answers
2005
Questions
0
Helped
162827
Points
6473
In theory yes, you should be able to move the hands of a clock to change it's time, but please seek out any knobs or dials on the side of the clock that allow you to twist them and alter the time of your clock as well.
Thank you.
  • ADMIN Andrew
    ADMIN Andrew Nov 12, 2022
    The OP must have made two posts, but your answer is basically the same as mine.
    https://www.fixya.com/users/sean-malone-...
Seth Thomas wall clock doesn't chime on the quarter, half or three quarter hour but does chime on the hour
Please change the time of your wall clock back 1 hour and check if the other 3 chimes return. There should be knobs on the side of the clock to help you do this. If not on the side, then please check on the back. Since you've already checked the settings and ruled them out as the cause of the issue (as well as the batteries), you might need to perform a factory reset on the clock if the steps I mentioned above fail.
Thank you.
How duo I change the time on my Sterling & Noble wall clock? It does not have any dials on the back to turn?.
To change the time on a Sterling & Noble wall clock that does not have any dials on the back, you will need to follow these steps:
  1. Locate the small, round hole on the back of the clock. This is the reset button.
  2. Using a small object, such as a paperclip or a toothpick, press and hold the reset button for about 5 seconds. This will reset the clock and allow you to set the time.
  3. Release the reset button, and the minute hand will begin to move around the clock face. Use the reset button to advance the minute hand to the correct time.
  4. Once the minute hand is set to the correct time, the hour hand will begin to move around the clock face. Use the reset button to advance the hour hand to the correct time.
  5. Once the hour hand is set to the correct time, the clock will begin to run normally.
I hope this helps! If you have any further questions, don't hesitate to ask.
Strausbourg manor quartz Westminster mantel clock. Why did it stop chiming?
Source: Wikipedia
The full hour chime is followed by one strike for the number of the hour by Big Ben (E3) (one strike for one o'clock, two strikes for two o'clock, and so on). ... The mechanism then plays two complete sets of five sequences for each complete hour.
Source: PortableFireplace
Learn how to fix a mantel clock that chimes at the wrong hour. This simple fix will repair a clock that chimes at the wrong time. This can commonly occur when your mantel clock is laid down on its back and the timing is offset.
1 Thing You Have to Understand First On most clocks you can turn the minute hand counter-clockwise but SOME clocks are not safe to be turned in that direction. For this reason, it's best to only turn your minute hand clockwise just to be safe.
The Simple Mantel Clock Adjustment The easiest way to adjust a mantel clock chime is to move the hour hand to the hour that the chime is striking. Make sure that the hour hand shaft is not too tight or else it will not turn. Most mantel clock hands are friction held. DO NOT BEND YOUR HOUR HAND, loosen the shaft if it will not turn freely.
Once you have synchronized the hour hand with the hourly chime, adjust the minute hand to set the clock to the correct time by moving it forward (clockwise) around the clock face. Allow the chime to strike at every quarter hour strike.
Mantel clock Chime Adjustment When your mantel clock chimes the wrong number of times, your chime is not synchronized time of the clock. To adjust your mantel clock chime, proceed with the following step:
ADJUSTING THE HOURLY CHIME
  1. When your mantel clock chimes, count the number of times it chimes. This is what time your hourly striker is set to.
  2. Move the hour hand to the hour indicated by the hourly chime (count the number of gongs at the hour).
  3. Reset the time using the minute hand to the correct hour and the chime should adjust along with the clock hands as well.
ADJUSTING THE QUARTER CHIME
On most mantel clocks, you can simple remove the minute hand which is friction fit. You have to apply pressure on the tube and it will loosen. Once removed, re-install the minute hand at the correct time. From there you can rotate the minute hand to reset the time.
Mar 17, 2021 • Home
I have an estate mantel clock that has started to chime on the 1/2 hr as opposed to the hour. it is chiming the correct time.
It could take an horologist a while to sort out why it suddenly changed. It isn't unusual for a chiming clock to chime at the quarters and half-hour as well as chiming and striking the hour. A quality clock usually allows the manner of chiming/striking to be selected and sometimes even the volume can be altered.
If your clock used to chime and strike the hour and now doesn't and appears to have slipped by exactly 30 minutes clearly something is happening. In the old days such things were often the result of turning the hands backwards to reset the time - that type of clock should be reset only by turning the hands forward and pausing at each quarter, half and hour to allow the chiming of each to complete. Most folk simply stop their clocks and wait for time to catch up...
It is also reckoned such a clock should not be kept next to an exterior wall but rather in a place where the temperature and humidity is the most stable.
Dec 02, 2018 • Chime Home
How to reset the clock?
Hello Ruth Anderson,
All mechanical... clocks (even quartz) should only ever be ADVANCED... In the springtime simply advance the clock and HOUR. In the FALL pull the plug, stop the pendulum...
QUARTZ WATCHES... Pull the winder stem out FULLY
(this removes battery...
Wait an HOUR... Plug the clocks back in... restart the pendulum
or push in the STEM on your QUARTZ WATCH...
(this restores power (and keeps the CROWN from coming unscrewed from the "winder-stem")).
Never turn the clocks backwards...
Modern clocks probably don't ACTUALLT MATTER
but antique clocks and timers can be UTTERLY RUINED
(It's just a good rule... & water RESISTANT seals happy).
Relative to the clock-face...
"FALL BACK - SPRING FORWARD"
SPRING = FORWARD ... advance the hands an hour.
Technically "time change" only ever occurs between
1am and 2am during each time zones respective hours...!!
Even on QUART
Hope this helps!
3answers
How to syncronize time with clock chimes? Howard Miller banjo clock.
The hands on your clock are probably friction fit, meaning that they can be adjusted, possibly even without tools. The hour hand is usually a firm slip fit over a tube, meaning that it can be slid forward and backward an hour or more as long as you hold the minute hand steady to keep the hour shaft from turning.
The minute hand may be trickier to adjust. Sometimes, it, too, is a simple friction fit, and you can pop off the hand (remove the second hand and pull the minute hand straight up off its shaft) before setting it where it should go. Other times, however, the minute hand is on a keyed shaft and has to go on in one of two directions. It's still possible that someone could have assembled your clock incorrectly, however, making the minute hand 30 minutes out of sync with your chimes.
If neither of these ideas helps you, please describe better exactly how the time isn't matching up with the chimes. That will help us better understand the underlying issue.
May 09, 2011 • Watches
I have a Schatz mariner ships bell clock (from 1955-60). Am not sure how to set it, especially for the bell strike...1 website says to move the hour hand, another says NEVER touch hour hand. Can anyone...
My Father severed his apprentiship at Augusta Schatz in Triberg. Never move the hour hand only move the minute hand, I know it is lond winded but does not un seat the hour hand fixing. But most important NEVER move the hand backwards ONLY forwards as this goes against the workings of the movement.
Dec 01, 2009 • Watches
I need to reset the clock because of the time change.
Look on the back of the clock.There should be a gear looking thing.Put your hand on that and keep it on as you turn the clock facing you.Turn the gear untill the hour you lost is accounted for.If it is electronic usually the manual will be able to tell you what buttons to push in corispondense to make it go backwards.Hope it helped you
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
