Computers & Internet Logo
Question about APC Computers & Internet
UPS BE500R-PH microcontroller pic16f716
Hi! just asking if I will buy new pic16f716 is it need to program? my ups microcontroller was damage and need to replace new one. but one thing I doubt before I buying another new one. do I need to program it before use it to my ups? or no need to program? and another question is there any available schematic diagram for APC UPS BE500R-PH? thanks in advance!
Posted by Waldo Pulanco on
  • Tesfay
    Tesfay Nov 19, 2022
    No, you do not need to program the new PIC16F716 microcontroller before using it in your UPS. However, it is recommended that you read the datasheet for the microcontroller to familiarize yourself with its capabilities and programming interface.
    There is no available schematic diagram for the APC UPS BE500R-PH. However, the following link provides a wiring diagram for the BE500R-PN:http://www.apc.com/us/en/faqs/FA156060/.
    You can use a multimeter to test a UPS battery by measuring the battery's voltage and current. To measure the battery's voltage, set the multimeter to the "DC Voltage" setting and touch the positive lead of the multimeter to the positive terminal of the battery and the negative lead of the multimeter to the negative terminal of the battery. To measure the battery's current, set the multimeter to the "Current" setting and touch the positive lead of the multimeter to the positive terminal of the battery and the negative lead of the multimeter to the negative terminal of the battery. I hope this helps.
Tesfay
    Passionate:
    Visited the website for 10 consecutive days.
    Novelist:
  • 139 Answers
No, the PIC16F716 microcontroller does not need to be programmed before using it in a UPS. However, it is recommended that you program the microcontroller to optimize its performance for your specific UPS.
There is an available schematic diagram for the APC UPS BE500R-PH. This diagram can be found in the "APC UPS BE500R-PH User Manual".
Check it here: Back-UPS ES BE500R User guide ' Schneider Electric (apc.com)
The most efficient way to use a UPS for a home computer is to connect the UPS to the computer's power supply unit (PSU). This will ensure that the UPS provides power to the computer in the event of a power outage.
Posted on Nov 18, 2022
Testimonial: "thank you! the schematic diagram is for service manual. not user manual. you provide is user manual not service manual. thanks anyway!"
Low voltage output 170 volts
Check your voltage meter, so it measures correctly, probably generate your UPS is not pure sine wave, but a modified sine, then the simple measuring devices to display the wrong value.
Apc us[p es 500 timer always reset
sounds like the battery is low or has been disconnected.
Tripping off of the Input protection
Need more info. What are the measurements on the input to the UPS. What is the total load you have? What other alarms are displaying? Check the input power to UPS. Also make sure the UPS is and will work for the correct voltage (Input of UPS) some UPS's are selectable voltages.
1helpful
I hear a continous clicking on my BE500R-PH ups when i turn it on. What seems to be the problem?..Allan...Philippines
Hi I also having the same problem here even replacing new batteries still doesn't give a fix, Im thinking it might be the relay?
NO POWER OUTPUT
you will need the copy of point of sale. i/e the cash register sales ticket then contact the manufacture, and request the unit to be returned, if that unit is new out of the box, well you will have 100% warranty.
ups is a battery backup unit, so contact the manufacture, direct. lhsjr
Top APC Computers & Internet Experts
Marvin
Marvin
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
