Re: Have model no. E2727B and it keeps saying other hand...
It sounds like you are experiencing some issues with your AT&T 2.4GHz DSS model E2727B cordless phone. Here are a few steps you can try to resolve the issue:
Make sure that the phone is properly charged and that the battery is not dead. If the battery is low, try charging the phone for a while before attempting to use it again.
Check to make sure that the phone is within range of the base unit. Cordless phones have a limited range, and if the phone is too far away from the base unit, it may display an error message indicating that the other handset is not in range.
Check to make sure that the phone is not already in use. If the phone is in use, it may display an error message indicating that the other handset is in use.
If none of these steps resolve the issue, you may want to try resetting the phone. To reset the phone, unplug the base unit from the wall outlet and remove the battery from the handset. Wait a few minutes, then reinsert the battery and plug the base unit back in. This should reset the phone and resolve any issues you may be experiencing.
I hope these steps help! If you continue to have issues, you may want to try contacting the manufacturer or your service provider for further assistance.
Make sure that the base has power and is connected to a working phone (land) line. To deregister all handsets, press and hold the Flash (on the left below the volume buttons) on the base for about 4 seconds. You'll see "Deregister all handsets?". Release the Flash button. Press the Yes soft key (below the LCD screen). You should see the base LCD screen read "Please wait". The registered handsets should read "Out of range or no power at base" until the deregistration is complete. Then you should see the message "Press Hold on base for 4 seconds and then press # on the handset" on all the handsets. The instructions are on pages 11/12 (page 15/16 of the PDF) of the handset manual. They are also in the full manual for the TL86109 on pages 135/136 (141/142 of the PDF) available here: https://att.vtp-media.com/products/TL/TL86109/TL86109_CIB_i14.0_20170526.pdf .
Possibly you just need a footswitch driver. Here's a download for one: http://user-guides.co.uk/download/olympus/olympusrs/olympus-rs-28-footswitch-driver.html
If you find a version 7.1 upgrade, be cautious about it, since I read that it often causes problems (google Olympus DSS version 7.1 upgrade and read about it).
Hopefully the driver will get you going.
Good luck, hope this helps, and thanks for using FixYa.
1.) The setup needs changing
2.) first off the dss-24 is a network switch not a router
3.) all of your pc equipment should be pluged into that device.
4.) chose one port as an uplink to your att modem
I think your problem is that the new modem is only giving out one ip address. So what ever first pc is turned on that is the one that grabs the address.
5.) you will most likly need a router to take the one ip address assigned via att then dole out additional ones. Remember the dss-24 is not a router. It simply connects everyone together. Each device still needs an ip address given from somewhere. Your old cable modem probibly did that but your new att dsl most likly does not.hence the new router will do that.....
to set it up do the following
2.) Find out the ip setup needed for your dsl service
A.) gateway ip
B.) primary & secondary dns server ip`s
C.) subnet mask
3.) get into the setup of your new router and then plugg in
all of these values using a fixed if address in the router
4.) connect routers wan port to one of the modems port. u may have to use a cross cable or straight look at the link lites to find out if they are talking to each other
5.) make sure that the routers lan side is setup for DHCP
6.) connect one lan port off the router to an uplink
of the dss-24. Then reboot everything
7.) viola it should all work internet on evey machine and file sharring.
I too was confused at first at setting the second hand after reading the directions. I read your post in searching for a solution, then I figured it out. Check the watch face, the second hand is operating using military time. (24 hr. time) You will see 24 hour time embedded on the face.
For example: if you wanted to set both hands to be at the same time to test this. At say 10 p.m. set the second time hand to 22 for 2200 hrs. (10 p.m.) Let's say you woke up at 7 a.m. The second hand would be at 0700 (Embedded on watch face) then at noon it would say 1200 on the watch face... I now use the normal hands for local time and set the 24 hour hand for my home time.
I hope this helps.
