Video Cameras Logo
Question about Sony Video Cameras
Rca 8mm tapes shot in EP mode will play in sony camcorder
Posted by stephen chamberlain on
Curt mueller
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 198 Answers
If the cassette tape uses the same format it will play back at the correct speed.
Posted on Nov 05, 2022
ADMIN Eric
    Top Expert:
  • Sony Master
  • 37,748 Answers
Good to hear it.
RCA 8mm tapes shot in EP mode will not play in Sony.
There doesn't seem to be much information but I guess your Sony can only play SP (standard play) tapes?
https://www.google.com/search?q=RCA+8mm+tapes+shot+in+EP+mode+will+not+play+in+Sony
Does theCanon UC-X2 camcorder play 8mm tapes?
Hi-8 camcorders might be backward-compatible for playing tapes. I bought a model which could be switched between the two modes - Sony DCR-TRV355E.
I have a working TRV81 Hi8 HandyCam and 15 Hi8 tapes I'd like to convert to digital and make ready for edit on IMovie (Mac). Would appreciate any advice....
The only way to do that is to play it in a device that plays Hi8 tapes and somehow converts it to a digital signal (likely through firewire as DV), then capture it to your computer just like a digital camcorder.
There are several ways:
1. Buy a device (like a camera) that plays it, output through RCA cables to your other camera or tape deck that is digital through the line in, and then just record that. (Alternatively, you could put that signal into a DVD-R machine and record onto a DVD, then just copy the files off the DVD, if you don't have a way to capture DV through firewire.)
2. Buy a device that plays Digital8 (same tapes, but miniDV FORMAT) and output directly from the tape through firewire. This means you must buy a SONY (only brand that made [now discontinued] Digital8) camcorder or deck [if decks were made, though those are usually expensive].
So, the simple answer: get a Digital8 camera and capture, or get another digital camcorder and a Hi8 camcorder and play through the digital one into the computer.
Buying a Sony Handycam (OLDER model) will be your easiest option, and probably possible on ebay, etc., for $100-$200.
Short of this, you could look to a friend or a professional solution for just getting the tape copied (like VHS->DVD services exist, there is probably some place you can mail your tape to).
EDIT: I should add: You included "8mm" in your title-- that is a bit confusing. 8mm refers to a few formats. One is film (obviously not what you're referring to), but then there is the older "8mm" tape format; it's like Hi8, but I believe it's actually not the same tape-- unlike Digital8 and Hi8which share a physical medium. I don't think you can get an 8mm -> Digital device, so you'd need to go through the RCA cables, as described above. [And though Hi8 is actually 8mm in width, it's not quite the same as the other "8mm" format... for whatever odd reason someone decided.... frown.gif]
However, I suspect you ARE actually working with Hi8, so this shouldn't be a problem.
I have a GE CG818A Camcorder, when I play it it only plays black and white. Was wondering if there is a used Sony or any camcorder that would play my Video8 P6-120MP tape, in color.
I have the exact same camera and same exact same problem. Any analog Video8 or Hi-8 camcorder or VCR will play these tapes.
By using the same cassettes as Hi8, many (NOT ALL) Digital8 (produced by Sony exclusively) camcorders are able to play analog Video8/Hi8 recordings, preserving compatibility with already recorded analog tapes.
you can connect Digital8 camcorders to your computer to download your movies for editing or Internet use.
As of 2008, Digital8 camcorders have been removed from the equipment offered by Sony.
Sticky 8mm sony tape
need to go to an AUTHORIZED SONY REPAIR SHOP to get it fix , these camcorders are very delicate and needs to be tune and realign by a SONY EXPERT TECHNICIAN , thanks AJ
Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Viewing SONY 8mm Tapes -- Please help
The older tapes were shot on a 8mm camcorder and the camcorder you have wil not play them becasue it doesn't have backwards compatability with the older format. The tapes you recorded are on a digital 8 camcorderr and it is different encoding than the one you recorded the other 60 tapes with. You will need to find either a dcr-trv 350 trv 530 trv 730 ect as these have the ability to play all the tapes.
Or find an older 8mm camcorder to play your tapes with.
Hope this helps
Cheers
Al
2answers
Multi-function DVD recorder VRD-MC5
Update to my 1/8/08 posting - my recorder is working perfectly! I found the installation of the needed file quite easy and all is good in the hood.
Later
RCA PRO854 camcorder
maybe I would buy your camera,
yes as far as I know hi8 and 8mm are completely different cameras,
where are you and how much for the camera?
[email protected]
Top Sony Video Cameras Experts
Marvin
Marvin
Jaime Hernandez
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
