Televison & Video Logo
Question about Hitachi Televison & Video
I have a Hitachi Zaxis Zx350lc-3 Zx350lcn-3 Zx350h-3,
Maintenance service filter kit set for Hitachi ZX350LC-3 ZX350LCN-3 ZX350H-3 ZX350LCH-3 ZX350K-3 ZX350LCK-3 Set1 also possible individually
Posted by Jhon Karls on
How do you perform a Maintenance Kit Reset on an HP T1200ps 44 inch plotter after service?
Perform the Reset Life Counters utility as follows:
1. In the Service Utilities submenu, scroll to Reset Life Counters and press OK .
2. Select Reset Maintenance Kit usage to reset the Life Counter for all parts included in a
Preventative Maintenance Kit (PMK).
You can choose from the following Preventive Maintenance Kits:
? Preventive Maintenance Kit 1 (PMK1). See Preventive Maintenance Kit #1 for 44-in models
(CH538-67024) on page 406 .
? Preventive Maintenance Kit 2 (PMK2). See Preventive Maintenance Kit #2 (CH538-67040)
on page 407 .
NOTE: For more information about the counters that are reset, See Preventive Maintenance
on page 400 .
It is also advisable to check the status of the Life Counters related to the other Preventive
Maintenance Kits to avoid multiple trips to the customer.
3. Select Reset usage counters to reset the Life Counter of a single part.
? Tubes and Trailing Cable
? Scan-Axis Belt
? Scan-Axis Motor
? Left Spittoon
? Right Spittoon
? Full Bleed Foams
? Carriage
? Service Station
Resetting for replaced MK kyocera fs 1135
press numeric keys 1087 1087 , then 251
Checking/clearing the maintenance count Description Displays, clears and changes the maintenance count. Purpose To check the maintenance count. Also to clear the count during maintenance service (replacing the maintenance kit). Method 1. Press the start key. The maintenance count is displayed. Setting 1. Select [M.CNT A] using the cursor up/down keys. 2. Change the setting using the cursor left/right keys or numeric keys. 3. Press the start key. The count is set. Clearing 1. Select [CLEAR] using the cursor up/down keys. 2. Press the start key. The count is cleared. Completion Press the stop key. The screen for selecting a maintenance item No. is displayed. Item No. Description Description Setting range Initial setting Maintenance count 0 to 9999999 0
3helpful
How to enter into service mode ricoh 8300dn
Ricoh SP8300 SP mode (Service Mode)
To Enter SP Mode (Service Mode)
Do one of the following:
If the power is already ON, press the "Home" and
"Simple screen" keys at the same time for more
than 3 seconds, and then press the "User tool"
key.
or
If the printer is OFF Press the "Home" and "Suspend" keys at the
same time while turning the main switch on.
Reset for Maintenance Kit A or Maintenance Kit B
So the "Replace Maintenance Kit A" or Replace Maintenance B" message will go away.
Once in SP Mode (Service Mode) press the following:
"ENGINE"
"SP-7XXX" - "DATA LOG"
"7804" - "PM Counter Reset"
"6" - "ALL CLEAR"
"EXECUTE"
I've tried to reset the maintenance-kit counter with this procedure but had no success 1 Turn the MFP off and then on. 2 When the memory count appears on the control-panel display, press and hold 6...
You can try to go in the service menu.
You can find this in the administration menu, go all the way down and you will see "service".
You need to insert the service code : 11434506
From there you can reset the maintenance count i guess.
How to clear the error replace maintenance kit
In service mode:
SP7804
7804 1 Paper
7804 2 Transfer Roller
7804 3 Paper Feed Roller
7804 4 Fusing Unit
Take note:
SP5930 001 Meter Click Charge
[0: No] default
This setting is for machines where the operator is responsible for replacing the Maintenance Kit.
(PM counter resets automatically after the user replaces the fusing unit.)
[1: Yes]
This setting is for machines where the service technician has responsibility for servicing the machine.
The service technician must reset the PM counter after completing machine maintenance.
50vs810 hitachi tv temp light is flashing, already replaced fan.
Where did you find the kit? I need a fan kit too. I would say replace all the fans in the kit. i am working on getting the service manual for this tv. This should help with how to replace the fans.
18helpful
HP 4345. Need to reset the Maintenance kit error. How do I get into ther Service Mode and how do I reset it? Thanks!
To reset the maintenance-kit counter
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. (This might take up to 20 seconds.)
3 Release 6 and then press 3.
4 Press 6 to select NEW MAINTENANCE KIT.
5 The MFP completes its initialization sequence. The maintenance-kit counter is automatically reset.
Scheduled Maintenance Items Are Not Detailed.
interval_box.gif Replace engine oil and oil filter interval_box.gif Rotate tires Inspect the following: interval_line.gif Automatic transmission and differential oil interval_line.gif Ball joints and dust covers interval_line.gif Brake linings/drums and brake pads/discs interval_line.gif Drive shaft boots (re-torque flange bolts) interval_line.gif Exhaust pipes and mountings interval_line.gif Rack and pinion assy. for leakage interval_line.gif Steering linkages
Additional Maintenance Items for Special Operating Conditions:
Driving on Rough, Muddy or Snow-Melted Roads interval_box.gif Inspect nuts and bolts on chassis and body Driving on Unpaved or Dusty Roads interval_box.gif Inspect engine air filter Towing a Trailer or Using a Camper or Car-Top Carrier interval_box.gif Inspect nuts and bolts on chassis and body interval_box.gif Replace automatic transmission and differential oil
Green haze not sharp
Good Day;
Sounds like your TV has a convergence problem. If you order KIT 10 from B&D ENTERPRISES at 1-800-458-6053 The KIT will include all parts neede and layout of part value & locations on simple paper lay out diagram. Or call FACTORY SERVICE;
1-800-448-2244.
Good Luck, big IRISH. PS or get from HIT Part X480293: kit.
1helpful
3answers
Hitachi 50" 50GX30B PJTV
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You can get a repair kit that includes all the parts from www.TvRepairKits.com.
They have put together a kit for the Hitachi TV sets.
The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
