Televison & Video Logo
Question about Magnavox Televison & Video
Can u access menu magnavox mwc13d5 tv/dvd by HOLDING DOWN TWO BUTTONS AT SAME TIME on front of the tv if original remote lost and no universals allow menu access(none
No remote,not any universal remotes work with menu button, all other buttons do work...repeatedly...JUST WANNA LOWER COLOUR AND BRIGHTNESS...not send to remote selling site please..(again,ONLY MENU BUTTON DOESNT WORK ON THE MANY REMOTES,NO FRONT MENU BUTTON ON TV EITHER(people keep sayn easy pleasy hit the menu button..****K!!
Posted by Doc Zirkle on
1helpful
I have set the t.v. up with a magnavox universal remote control, and I can't find the up and down or left to right to hookup wifi
If you are trying to set up WiFi on your TV using a Magnavox universal remote control, you may need to use the remote's navigation buttons to access the TV's settings menu. These buttons are typically labeled "Up," "Down," "Left," and "Right," and they are used to navigate through the TV's on-screen menus. To use them, follow these steps:
  1. Press the "Menu" or "Settings" button on the remote to access the TV's settings menu.
  2. Use the "Up," "Down," "Left," and "Right" buttons to navigate through the menu options.
  3. Select the "Network" or "WiFi" option and follow the on-screen instructions to set up your WiFi connection.
If you are unable to access the TV's settings menu using the remote's navigation buttons, you may need to refer to the user manual for your TV or universal remote for more detailed instructions. Alternatively, you may need to contact Magnavox or the manufacturer of your TV for assistance.
tip
Acessing Menu with universal remote
We used a One4All model URC3021BOO remote. We programmed BOTH the TV function and the DVD/vcr button with code 0807.  To access the menu PRESS TV then MENU button then DVD/VCR button will allow you to change menu functions using left and right and select buttons. *TV button will access Menu screen BUT NO menu functions. * DVD/VCR button will NOT access menu screen but WILL control menu functions if menu is already displayed. May work with other sharp products, or other universal remotes? These original (RRMCG1330PESA) remotes run 38.00+ to buy new so try this FIRST!
2006 Magnavox TV DVD VCR combo no remote control no menu button on the TV how can I access the menu??
Buttons located on the top and right side can be used to replace the remote functions. See the diagram below.
Of course you could always buy a universal remote and program it to the unit.
Magnavox #MWC13D5 no remote have converter box Two channels are blocked Parent controll Can TV be reset or can any of the buttons on the front bring up the Menu
Without a remote control, you can't access its menu. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
Electrohelponline
I have a panasonic PV-M2768 and i don't have the original remote. I have a RCA universal RCR312W. I have tried all codes I can find. (interesting side note: the remote manual says to enter a 4 digit...
Universal remotes are a very limited devices for a replacement of a remote.U get the tv for power on/off,channel up/down and volume up/down,the basic that all u will ever get it out of the universal remote.No button said Menu on the front of the tv for acessing tv Menu,than sorry no combination of buttons,will help u to access the tv Menu.Sorry,but now,u must buy the tv original remote.Try website like Remotes.com to buy an original remote.
2helpful
Dead remote = no dvd access?
Try a RCA universal remote with an input button. Try the codes for Orion , Sansui and RCA. Access the menu by holding down both volume buttons on the front of the set. There is no access to the jacks on the front of the set without a remote. If all else fails get a RF Modulator. This will allow you to watch your dvd by using the antenna jack on the back of the set.
2answers
No remote specific to Sharp combo unit..how to turn off closed captionning
on some models the menu button is on the front disguised as the volume up/down or channel up/down buttons. you have to push both up/down buttons on either one of these to bring up the menu.
2helpful
Can not access setup
hit vol down on the tv and hold then with your universal remote puse 1. This will set the tv back to factory defaults and give u acess to all cable channels.
Top Magnavox Televison & Video Experts
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
