I cant seem to find ones with thr correct ends to go from the bike to the will they all look differentI cant seem to find ones with thr correct ends to go from the bike to the will they all look different
AnonymousNov 03, 2022
I looking for this cable many thanksI looking for this cable many thanks
Like this Like this
You can't post conmments that contain an email address.
the wii remote probably isnt conected... go to your wii device open the little tab to where the sd card should be. then open your wii remote and you should see a reset button on both of them (a red button) hold them both down at the same time... it syncs them also you may need to charge the wii remote
It should be able to connect via wireless. Simply switch on your Wii console, insert the disc and Cyberbike will
connect via wireless access, just follow the simple instructions and
you're off.
Hello, Yes, there is a manual, it can be downloaded at www.cyberbike-thegame.com click on the support section. It is likely that you have a defective handlebar if the Gamecube controller is not an option. If it is the case, we will send you free of charge a replacement. Best way to proceed is to send us an e-mail at [email protected]
had this problem too!! they didn't tell you this in all the instructions! it took me a while to work it out.
What you have too do is when you start the game and you are actually in the game, (you are past the advertisment bit) you have to have your bike switched to gamecube as your lead is connected to the game cube section. you can then have to select the game cube remote this means you can use the bikes controls rather than holding the wii remote.When you have clicked on the game you want you then have to switch the bike back to the cyber bike you can then pedal doing it this way seems to set the bike for use.
i have tried many combinations and this has worked!
the switch i am talking about is the switch on the main part of the bike controls at the bottom in front of you!
good luck i hope this made sense and it works for you!
Look into http://www.fixya.com/support/t7615389-get. It'll work definely well with you Cyberbike paddling as speed control as well! Oh a word of warning, it's very very tiring to bicycle with 'Mario Kart' - an 'extreme excercise' NOT Recommend for old forks or 'light hearted' person!!!
PS. Wants more, the Cyberbike also supports 'Need for speed - Undercover' & 'Donkey Kong' !!!
Have fun...! As I'm cycling everyday with my Cyberbike Kart...
With some searching found english manual at http://www.cyberbike.be/sitemapENG_test.html
have to scroll down to support section. Then in the PDF section 4b has section to restore manufacturer's calibration. This worked for us.
