Computers & Internet Logo
Question about Acer Computers & Internet
Acer aspire m5-581t 6405 won't boot up
I replaced the motherboard and hard drive. Push the power button. Upon start up I receive a message ; no bookable disc. Keyboard is non responsive. So I can't enter bios to set disc startup order. Wondering if it's a bad keyboard.? Or what?
Posted by Gary Marshall on
  • 1 more comment
  • Mike Lann
    Mike Lann Nov 02, 2022
    can you go to the settings if so change the download from disc to zip drive under settings also I have cheated and first put drive in second shut down system restart and tap f5 Good Luck
  • Gary Marshall Nov 02, 2022
    Can't enter bios at all. No response to keyboard
    I've checked the keyboard ribbon. Looks ok. Look like it's seated properly.
Mike Lann
    Sergeant:
  • 255 Answers
The BIOS is reading that you have no start up data in the systeam. You will need a set of windows with the code when you put the disk in then power up computer it should start asking questions Good Luck Mike L.
Posted on Nov 02, 2022
Testimonial: "The disc I have is windows on a USB drive. It won't read the drive"
6helpful
5answers
Pxe-E63 : error while initializing the NIC
Check the boot sequence. For a normal boot, it should be set to hard disk as first item, not the network.
How to restore when laptop won't boot up
try changing boot divice at start up you hard drive may have falled
Acer aspire 5253 error message no botable device after laptop was dropped on carpet
No bootable device suggests that your Acer Aspire hard disk may have been damaged when the computer was dropped.
You should try opening the cover on the base of the laptop where the hard drive is fitted and check to make sure that the drive is seated firmly and has not come loose with the drop. See the Acer Aspire 5253 Quick Start Guide for the location of the drive cover.
If reseating the drive does not help, then you would need to find any recovery discs that you may have made or received with the laptop plus need to buy and install a replacement hard drive.
Sir ,i have acer aspire 4520 laptop .when i boot my laptop it will show message below pxe-e61 media test failure ;check cable existing nvidi boot agent and my laptop loss display for sometime & again...
Usually when a computer displays a "Media Test Failure" message, it is a good indicator that the hard drive is/has failed. The solution would be to replace the hard drive in the laptop.
Acer aspire m1201 not booting up - I powered it down normally and moved it to another location. I have opened up the tower and I have reseated anything that I could and pushed on other cords that were...
Please check to see that the LED light on the motherboard is lighting up. Also, if the BIOS appears on the monitor, please make sure that the hard drives are properly connected and that you can hear then spinning and/or see the Hard Drive LED light up. It sounds as if your motherboard is receiving power, but something else is not. Please also make sure that your processor's heat sink is properly seated and secure.
My acer aspire am5100 desktop needs a recovery to wipe the hard drive. I have the discs, but when they are placed in the drive, the system doesn't recognize them and starts up normally. It basically...
With the first recovery disc in in the drive, and starting from a powered off machine, press the power button and then press quickly and repeatedly on the F12 key. The boot menu should appear. When it does, make sure that CD/DVD/Optical whatever drive is highlighted. If it's not, use the up and down arrow keys on your keyboard to highlight it. When it's highlighted, hit the enter key.
The second you see a white message on a black screen that says...."Press any key to boot from CD" hit a key and begin to follow all the prompts.
You should be ok after that.
Regards,
Selk
Acer laptop will not turn on.
You must now assemble it again by taking out components carefully and fix it properly it is due to lose connection in your laptop
thanks
Acer aspire 5610 new hard drive need to load xp operating software help!
hey... to install XP to the hard drive, u need to restart the PC with XP CD in the Drive... When the computer starts up you'll need to press F10 or F12 to bring up the boot menu (it depends upon ur motherboard type).. select boot from CD n follow the instructions....
Acer Aspire 5050 won't boot at all
Yes, it's not the hard drive.
More than likely it's your motherboard.
There's not much you can do besides trying to boot the computer without the battery, and removing and reinstalling the memory.
Hopefully you'll get lucky!
Acer aspire 3680 - new out of box won't boot
NEED TO DEL PARTIONS MAKE NEW ONES FORMATT THE HD THEN INSTALL XP AGAIN AND UPDATE
Steve Sweetleaf
Steve Sweetleaf
shadow
