p
patrick mutebi Posted on Nov 01, 2022
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can i fix my canon 2320 which prints a blank page yet there is enough toner?
The printer prints a blank page yet there is enough tonner
Robert cruse
Level 3:
Master:
  • Canon Master 336 Answers
  • Posted on Nov 03, 2022
Robert cruse
Canon Master
Level 3:
Master:
Answers
336
Questions
22
Helped
299720
Points
1037
Printer Printing blank page issue can be occurred when you have low or dried ink cartridge, blocked nozzles, dirty print head and ink cartridge installed improperly. Follow the troubleshooting steps to fix printer printing blank pages:
·Restart the printer
·Check printer ink cartridge
·Clean the printer print head
·Update the printer drivers
Follow more steps to fix the Printer printing blank pages issues
ADMIN Andrew
Level 3:
Top Expert:
  • Canon Master 66,967 Answers
  • Posted on Nov 01, 2022
ADMIN Andrew
Canon Master
Level 3:
Top Expert:
Answers
66967
Questions
Helped
5088258
Points
379837
Toner?? This is an Inkjet printer! Toner is the other technology using dry powder in a cartridge laying the toner powder using a photo-electric transfer and heat to fuse the image to the paper. Yours is liquid ink sprayed trough nozzles.
Support answers in the link.
https://www.google.com/search?q=canon+2320+printing+blank+pageshttps://www.google.com/search?q=canon+2320+printing+blank+pages
Roger R
Level 3:
  • Canon Master 2,005 Answers
Roger R
Canon Master
Level 3:
Answers
2005
Questions
0
Helped
163742
Points
6473
Please double check that the nozzle of your printer is clean. Also, please run test prints with different document to check for any change to the issue afterwards.
And you'll want to restart both your printing source (ie computer) as well as your printer before attempting another test.
Also, please check that toner that you're using isn't a 3rd party toner as printer companies have updated their software to block these from working with your printer.
Thank you.
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
2answers
The pages are not printed
sometimes in this case the dram needs to change (
Tonner exhausted and replase tonner fw 1.18
When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Samsung 4300 tonner exahust message
A laser printer needs toner to print, when this runs out the printer will print either blank or very faint images.
You need to replace the toner cartridge with a new one or a re-manufactured toner cartridges. Re-manufactured toner cartridges are cheaper than new toner cartridges for your model printer.
1helpful
Hello! I needed to print 6 pages...the first one printed, then the printer started sending out blank pages and lots of them. I had to turn off printer to stop the blank pages from feeding through the...
Hey this might be that the toner is empty, get a shop to either refill it or purchase a new ink tonner for your make as you will take it to them and they can match it up. So you get the correct ink for your printer.
Did it print one and then spend out 5 pages exactly. If this be the case then it confirms that the ink tonner needs to be replaced. You have run out of ink.
Please take the time to rate my expertise.
Thanks
5helpful
2answers
Canon imageclass mf 6530 blank pages change toners still blank what is the cause of this problem
you have problem with laser shuter on laser unit. It needs to be fixed or replaced.
This is canons factory fault, and if the machine is under waranty call service.
Hope that helped!
17helpful
2answers
How to refilling toner in canon lbp2900b
it a very easy to refill the 12 A tonner
remove the drum from cartriage then find 2 hook fixed the cartriage just relese it you find your cartriage divided in to 2 parts relese the nut from other side of the cartriage open the cap then fill with the tonner fix all
5helpful
4answers
Print but blank pages come out - changed the toner
I just had tech from Canon and replace a part that took hime 5 minutes. He said that the part replaced allows the image to appear on paper and it was a common issue.
Printing blank pages
The problem is may be scanner assembly of the printer or tonner sensor check this peripheral if possible.
old marine
old marine
ZJ Limited
ZJ Limited
