My remote is showing the infrared light and I have a harmony universal remote with hub I had been using for years and all of the sudden neither one is working the receiver at all. The receiver seems to work mainly but I can't get it to do anything without it. I tried to get on the website for the harmony App to see if I could make it work through there and still can't get it to work. I have unplugged my receiver and kept it off die a long time. I checked the wiring and it seemed ok. Any help would be appreciated!!!! I don't want to get up to change the volume and my devices every time.. especially when rhe commercials get louder lol Thanks!!!
1. Check your receiver's input:
If you're having trouble getting your Sony STR-DN850 to play nice with your receiver, the first thing you should do is check the receiver's input.
Make sure that the receiver is set to the correct input for the Sony STR-DN850. If you're not sure, consult your receiver's manual.
2. Check your Sony STR-DN850's output:
Next, you'll want to check the Sony STR-DN850's output. There are a few things you can check here. First, make sure that the Sony STR-DN850 is set to output audio to your receiver. You can do this by going into the Sony STR-DN850's menu and checking the "Audio Out" setting. Second, make sure that the Sony STR-DN850 is outputting audio in the correct format.
If you're not sure, consult your Sony STR-DN850's manual.
3. Try a different receiver:
If you're still having trouble, you may want to try a different receiver. Sometimes, different receivers can play nicer with the Sony STR-DN850 than others. If you have a friend or family member with a receiver, see if you can borrow it for a few days to see if it makes a difference.
4. Check your receiver's remote:
Finally, if you're still having trouble, you may want to check your receiver's remote. Sometimes, the remote can be the culprit when it comes to receiver/Sony STR-DN850 compatibility issues.
Make sure that the remote is set to the correct input for the Sony STR-DN850 and that all the buttons are functioning properly. If you're still having trouble, you may need to consult your receiver's manual.
Posted on Nov 22, 2022
Testimonial: "Unfortunately, this does not help. I know the issue is that the receiver will not connect to ANY remote right now. I need to know what I can do to get it to connect to a remote. Is there a way to reset it or anything?"
I suggest that you check the manual. May be you might get some answers.
Try resetting the remote by removing the batteries and then replacing them. If that doesn't work, you can try resetting the remote by holding down the "Reset" button for five seconds.I hope this help! Good luck!
