Watches Logo
Question about The Watches
Ch-899 chouchin wifi clock
My wifi ckock second hand stops each night at 12am till 6am , the minute,hour hands keep moving correctly , is that normal ? may be from power saving point of view ?
How do I set the Chimes on the Ergo Westminster Clock
The controls on the back of the Ergo brand Wall Chime Clock are different than that of the Seiko. I'm not sure who makes the movement - probably Chinese or Asian. Anyway, always take the pendulum off the hook before moving the clock about as it can damage the mechanism. On the back, there is a dial for adjusting the time setting of the clock hands, which is awkward to use, but does work, easiest to leave it alone and use the minute hand, NEVER the hour hand. There is a dial for volume. There is a switch for type of chime - Westminster or Wittington. There is the night-time shut off or volume reduction. Some models have a switch for chiming every quarter hour. My advice is make sure you have fresh batteries, and set the switches on the back for the settings you want. Hang the clock, grasp the pendulum arm and re-hang the pendulum, making sure it's hooked in properly. Now, whatever the hands say the time is, ignore it for now, and gently move the minute hand backwards, slowly, to about 5 minutes before the top of the hour, then forwards to a couple of minutes past the top of the hour. This will cause the chimes to start. Let the melody play, then listen for how many "clangs" you get. That will tell you what the clock thinks the time is. For example, if it "dongs" 5 times, and you've set it to run silent at night, the clock thinks it's 5 p.m. If it's actually only 3:15 p.m., then gently run the minute hand backwards til the hands indicate about 10 minutes behind the correct time (it'll take you several minutes to complete the process) then gently move the minute hand back to about 5 minutes before the top of the hour, then forward to a few minutes past, and the chime will start to play the melody. If you let it, it will play out the full melody, then it will "clang" one more time than your previous test. Each time you move the minute hand back to 5 minutes before the hour, it advances the chimes by one hour. Here's a tip - you don't have to let the melody and "clangs" play fully, each time, once you know how it works. If you have it set to run silent at night (pre-programmed to silence after 10 p.m. to 6 p.m.), keep moving the minute hand back to 5 minutes before the hour, keeping track of how many times you've done it until you reach 10 p.m., or not, until you get to the point where you move the minute hand back and there's silence. At that point, the auto-silence mechanism is active, and the clock thinks it 11 p.m. So, from that point, keep repeating the process of gently moving the minute hand back and forth, from about 5 minutes to the hour, to a few minutes past, keeping track of how many times you've done it. After 8 sequences, you hear it start to chime again, at 6 a.m. So, at that point, go through the back-up and advancing of the minute hand sequence 9 more times, and on the 9th time, let the melody play, and let in "clang" to determine that you're indeed at 3 p.m., which you should be. Then simply gently advance the minute hand to the correct time, 3:10, 3:12, whatever, and you're done. You'll know for certain soon enough.
Apr 02, 2012 • Watches
1helpful
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 • Watches
1helpful
I have an antique clock that requires two places to wind it up. Since Daylight Savings Time went into effect, the clock has gone crazy, chiming the hour on the half hour and chiming three hours ahead. What...
With only limited information provided about your type of actual antique clock this symptom has to conclude that your clock is a non self correcting style.
Step one: Ensure clock is striking the hour. during the time of the hour strike quickly move the minute hand to the hour.
Step two: Move to the half hour allow to strike, move hand to hour allow to strike then move the hour hand to align with the correct count.
Step three: Stop the clock until the correct time has been achieved and start clock OR strike ever hour and half hour until clock is set to the correct time.
Hope this tip guides you to a solution for your clock.
r/ David
http://antiqueclock.clockstop.com/
Apr 06, 2010 • Watches
1helpful
2answers
My new wall clock chimes 2 minutes BEFORE the
You will need to do a mechanical adjustment to the hand.
Loosen the hand nut and adjust the hand the tighten.
Hope this tip helps to solve your problems
R/
David
Mar 19, 2010 • Watches
1helpful
How to change the hour
Anniversary clock hands can be adjusted directly moving the minute hand clockwise. Do not touch hour hand as this may cause hand disalignment. Carefully move minutes hand with your finger all the way around till you reach desired time.
Do not forget to rate, please.
Need instructions on National Geographic Men's watch #NG010GYSK
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
2answers
How do you set and deactivate the alarm function.
I did find two authorized dealers:
www.kenmarwatches.com
www.princetownwatches.com
Contact both and request users manual fur your specific model. They must be able to help.
58helpful
7answers
Instructions for casio wave ceptor 4303
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Top The Watches Experts
vince
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a The Watch Expert? Answer questions, earn points and help others
