I have a Bose Wave CD player where the copper ribbon beneath the CD player became unattached from the player when trying to clean the laser. How do I reattach it to the CD player?
You could try to clean the laser, with a special cleaning disk. Don't try to clean a laser by opening the player, you will damage the system.
If it is a CD burned in a PC, it also can be the laser is now a bit less, not capable reading CD-R or CD-RW, and still can read normal CD's
Read my other post over CD players
You have done what i would have suggested, the Bose Wave unit will need to back to Bose for service, and there is a good chance they will need to replace the laser pickup assembly and cost should be considered even thoe it is top of the line.
The cd assembly is the issue, over a period of time the laser pickup becomes weaker until it can no longer read the disc, one possible solution is to buy a disc cleaning kit and follow instructions in an effort to recover the assembly. If that fails the only option is contact Bose for pricing since they are the only authorized service centre that work on their own products.
Yes you have a defective laser assembly. The 139 is a great price as buying the laser lens alone will cost you around 70 .Bose will also upgrade with any new software and will also provide you with a 1 yr warrenty.
Try removing the cover and clean glass laser eye lens with rubbing alcohol and cotton swab. If cleaning doesn't work, then laser lens circuit will need to be tested and replaced. You can use an ohmmeter to test the capacitors and circuit.
If the fault is more involved the unit will have to be serviced, you should contact the manufacture to find out about who in your area can service your player.
You must contact Bose directly for replacement parts. Most manufacures normaly sell the complete transport as a replacement part.
When changing the laser, or simply removing and re-installing the original, the proper calibration set-up will be required. This cannot be done by eye or ear. This also includes installing a complet new laser assembly.
I've repaired about 10 type Bose AWRC3x (the radio/cd model with lift up lid and top controls). If the cd won't play or skips, try cleaning the lens VERY carefully with a cotton bud with some isopropyl alcohol. Let it dry then try again. This will help in about 1/3 of cases.
After that, a new laser unit is needed. They cost around 15 pounds,30 dollars, (Type SFP100s with 13 pin connector made by Sanyo). You need to have some electronics experience to take the case to bits to get the laser deck out, change the cd laser and reassemble. Basically, DISCONNECT THE POWER! Remove the 3 screws on top, turn over and carefully prise the front of the base away from the top cover with a table knife or similar. Lift off the top cover - be careful with the lid ribbon! The deck can be disconnected from its ribbon cable and wired connector very carefully. Take the deck to bits and fit the new laser head (take photos if you think it will help). Remember to unsolder the shorting 'blob' of solder which protects the new laser from static till its fitted.
On the bright side, there is no tracking etc to set up, that's all automatic so usually they work like new with a new laser fitted. I have to say this is the weakest feature on the Bose CD radio, the actual electronics rarely gives trouble.
