Baby Gear Logo
Question about Baby Gear
We have been given a Mothercare Taunton cot bed WD246SH...but we have no fittings, nuts or bolts of any description. Can anyone supply the full set ?
Posted by Robert Sharp on
R SHOAIB
    Master:
  • 567 Answers
Unfortunately, I cannot supply the full set of fittings, nuts, and bolts for your Mothercare Taunton cot bed. However, you may be able to contact Mothercare directly or search for spare parts on their website. They may be able to provide you with the appropriate parts or direct you to a supplier. Additionally, you could try searching for the specific fittings, nuts, and bolts online or at a local hardware store. Make sure to take accurate measurements and bring a sample of the part if possible to ensure you get the correct fit.
Posted on Feb 28, 2023
ADMIN Andrew
    Top Expert:
  • Baby Gear Master
  • 57,350 Answers
Contact Mothercare direct and they should be able to get a full set. Or if you go to B&Q or Sainsbury Homebase, you should be able to pick up fasteners that will fit.
All the parts as listed on Page 4 of the manual with the number you need. The problem part might be Part 'J'.
https://www.mothercare.gr/sites/default/files/imported/manuals/Taunton_Cot_Bed_Mothercare.pdf
More
https://www.google.com/search?q=Mothercare+Taunton+cot+bed+WD246SH+parts
Posted on Oct 27, 2022
I purchased bunk bed for my kids in US, Creekside taffy twin/full step bunk bed.
The number of different sizes is confusing and it is important to measure carefully in order to order the right ones.
Few people will be able to tell you what size you need and I can't. When I bought two sets of bedbolts online a while ago I found the barrel nuts and bolts were supplied in sets and I needed to know the bolt diameter and length and the diameter and length of the barrel nut. The website I used showed how to measure and if you still have a nut this will be simple for you.
I had no nuts or bolts and had to start from scratch, which was simple once I had found something like a rod or tube that was a good fit in the bedframe - a matter of inserting it and marking it and then measuring the diameter and the distance to the mark.
In reality I found the sets of bolts so cheap it made little sense not to order spares. They arrived 2 days later. If you are in any doubt why not order a few sizes...
The method of fixing the bedframe together is so crude even the wrong size of nut and bolt will sometimes be enough to hold it together, though for strength and reliability the right size is obviously better.
I suggest a google search for bed bolts and nuts and then visit a few sites to check ways of discovering how to measure.
Apr 17, 2017 • Baby Gear
I have a WESTBURY COT BED and one of the drop side guide pins has broken and needs to be replaced.
No! And this is a critical component. I hate to tell you but you should throw the drop side away. You can use as a toddler bed or headboard and footboard to a twin, but it is unsafe as a crib and this is a prime example of why drop sides were banned.
Nov 21, 2014 • Baby Gear
Where can i buy cot bed screws. 6mm x 6.5 for a sandringham cot from john lewis. 4 dowels are missing also. thank you
Hello, MY NAME IS Philip Lees and i designed the Sandringham cot bed, I supplied it to John Lewis for 12 years, it was there best selling cot throught them stocking it.
I think I have a full set someware so if you still require them please let me know. Kindest regards Philip
Sep 04, 2011 • Baby Gear
I would like to change my mothercare cot bed into a cot
  • Here is a link to the manual for a Mothercare Cot/Bed
http://help.mothercare.com/resources/mothercare/products/Bordeaux_cotbed_instructions
  • This will provide you will the illustrations necessary to make this change as well.
Regards, Tony
Apr 26, 2011 • Toys
4helpful
Replacement screw set winnie the pooh cot bed
Just ring the mothercare customer service help line and they will order them for you free of charge - you do not need your receipt.
Feb 09, 2010 • Baby Gear
3answers
Have a cosatto hogarth cot bed main side rail
If this is a Cosatto product, visit this link and you should be able to resolve your issue:
http://www.cosatto.com/contact.php
I hope this helps.
Sep 20, 2009 • Baby Gear
24helpful
3answers
Assembly Instructions Durham Cot Bed
Have attached a copy of my instructions
Mar 10, 2009 • Baby Gear
1helpful
2answers
Cosatto SJ300 cot bed fixing parts and assembling manual
Try a company called www.delivered2you.co.uk
Oct 24, 2008 • Baby Gear
Top Baby Gear Experts
Marvin
Marvin
john h
ADMIN Andrew
ADMIN Andrew
Are you a Baby Gear Expert? Answer questions, earn points and help others
