Cameras Logo
Question about Canon Cameras
Cannon film camera broken
Help! I own a canon sure shot Z135 zoom 35mm camera and it will not fully turn on. I have changed the batteries that were only a few months old to new barriers and there was SITLL no change. The small digital screen shows a full battery and 0 shots taken but when I go to turn the dial to auto or any other mode apart from off a quiet beep goes off and the camera lens does not open and camera does not turn on. Iv tried everything from changing the batteries and still the camera is making a beeping sound! Please help!
  • Canon Master
  • 19,166 Answers
There is an internal battery that you cannot change. When it goes out, the camera fails. There are several places online that you can send it to for repair
Posted on Oct 26, 2022
Howw do you rewind the film on a cannon sure shot megazoom 105
Their is a small button on the bottom you push in then rewwind the film to take it out.
How to load film
http://www.usa.canon.com/app/pdf/compact_film/Sure_Shot_Z135_manual.pdf
The link above will take you to a .PDF that is an owners manual for the Canon Sure Shot Z135
On page 14 it lists how to load film into the camera.
1. Slide the back cover downwards
2. Insert the film
- Make sure the film is positioned above the film guide
3. Pull the film tip across until it reaches the film tip marker
- Make sure the film is flat
4. Close the back cover
5. Turn the dial to (auto)
(Turn the power on)
the camera will automatically advance the film to the first frame.
6. "1" should be displayed on the frame counter
If this show zero there has been an issue, make sure you are using the proper film for the camera
I have an old Canon 105 zoom sure shot. I want to get the old film out but the battery is dead. I don't want to purchase a new battery. How can I accomplish this? Thank you [email protected]
If you have a changing bag, you can put the camera inside, open the back, remove the film, and rewind it by hand. You can also do the same in a darkroom (a photographic darkroom, not just a dark room). A good camera store can do it, though you'll probably also have to have the film processed there.
If you have any plans to use the camera in the future, you may as well invest in a battery now. You can take the battery out of the camera and set it aside to preserve the charge.
1helpful
I lost the manual for my Canon sure shot 105 zoom. How do I load the film?
You can download the manual at
http://www.cameramanuals.org/canon_pdf/canon_sureshot_prima_105_zoom-1.pdf
I am unable to get a new battery for Canon Cure Chot ZOOM-S. Please can you help?
The Sure Shot Zoom S uses a 2CR5 6V lithium battery. You should be able to find one at an electronics or office-supply store. If all else fails,
http://www.batteriesplus.com/product_search/31018-Rayovac-2CR5-Lithium-Battery-1-Pack-DASH--DASH-RAYRL2CR5--1.aspx
1helpful
2answers
I have an old 35mm Canon Sure Shot 70 Zoom. There is film in the camera, but the battery is dead. I can't find the owner's manual and want to know if I'll expose the film if I open the camera to change the...
You don't need to open the camera to change the film. The battery door is on the other end. You open the door by inserting the protrusion on the plastic end piece of the strap into the slot of the battery door. It takes a small 3 volt battery.
2answers
Owners Manual
No need for manual it is just an aim and shoot camera it has two modes auto and program. You better use auto mode.
If you want specifications this is the link,
http://reviews.cnet.com/cameras-non-digital/canon-sure-shot-105/4507-9339_7-30402902.html?tag=specs
3helpful
Canon Sure Shot 105 ZOOM ~TOTALLY LOST ~need any instructions I can get.
The flashing H means hat the camera has detected a hardware fault on starting up. It can also mean that the film has mis-loaded. Try removing the film & then the battery to reset it. Put the battery back & switch on. If it's still doing it then I'm afraid it's got the 'flashing "H" of Doom'. Although this is repairable, it's usually not economically viable.
Instructions
There are two conditions under which a blinking "H" will appear in the
LCD panel: (1) when the film has been loaded incorrectly or (2) when the
camera's self-test process detects an internal malfunction. If a
blinking "H" indication appears, perform the following operations in
attempt to resolve the situation:
1. Rewind and remove the film using the rewind button, then remove the
battery to clear the memory.
2. Clean the contacts at the base of the battery compartment with a
clean pencil eraser to ensure proper contact between the camera and
battery.
3. Replace the battery, power the camera back up1.gif and operate it as if
it had film loaded, pressing the shutter release.
Top Canon Cameras Experts
old marine
old marine
David Shaub
shadow
Are you a Canon Camera Expert? Answer questions, earn points and help others
