Fisher and Paykel MW511 Washing Machine. Some buttons work on the display panel . Others don't ==> Smart Touch Cycles, Spin Speed, and most importantly Start/Pause (you can press them but nothing happens except a delayed click noise).
If you can get to the control panel and the buttons, check the connectors on the edge of the boards. You are probably going to need a service call. Control boards are expensive, so they need correct diagnosis, plus you get warranty on the repair.
Testimonial: "Hi Andrew, already had a look at the control board. All clean and looking fine. The machine won't do a diagnostic test. When you turn on the machine it lights up and powers up ok. Just some buttons don't work and the Start/Pause button is doing nothing."
Please power cycle your washing machine by unplugging your machine for 1 minute before plugging it in again.
If this issue reoccurs , then please check that there are no debris at the bottom of the washer. And you can double check whether the washer door is being shut properly.
Thank you.
Testimonial: "Tried. No change."
