How do you set a popart pop-693ad watch
Ok, it took awhile to remember, but to reset the analog time or the day or anything else, first push the "mode" button which is at the 8:00 position on the side of the watch, 3 times. The first push will bring up the stopwatch, the 2nd push will change the alarm time, the 3rd push will highlight the seconds which on the watch face is at the 6:00 position. Release after the 3rd push and push the "reset" button which is located at the 4:00 position. It will start flashing the hour first. If that is what you need to change, then push the "start" button which is at the 2:00 position. Either keep pushing the start button to set the hour or hold the button in if you have more than a couple of hours to change. When that is done, if you need to change the minutes, push the "reset" button again and the minutes should be highlighted and do the same thing with the "start" button until you have the minutes set where you want. When you are done changing whichever thing needs to be set, including the alarm time, push the "mode" button and everything will stay set. This is for the Pop Art 693 AD watch which if you buy through ebay, it's an awesome watch with dual analog/digital time displays, etc. it comes with no instructions. If all else fails, go to the jewelry counter at a Walmart and hopefully the worker there can help. We found that once with a different watch. I hope this helps everyone!!
