Try cleaning the tip of the wire that is near the flame nozzle...that is the heat sensor (thermocouple) which waits to get hot before it allows the gas to flow to the nozzle (safety measures) without the need for anyone to hold in the knob.If the wire is dirty or two short the gas will just stop once you release the knob.
Cookers have a flame failure safety device. Yours may be faulty.
They are designed so that if the flame goes out then the gas shuts off, but it may think there is no flame and keeps shutting off despite it being lit.
Will need an expert on this I think.
Mar 18, 2008 - Similar Questions: light pilot stays till release button suggestions ... If you have held it for a long time and it still won't stay lit, then your thermocouple is bad.... the gas valve doesn't think a flame is burning the gas coming out of the pilot ... less likely but somewhat common is the gasvalve... if the knob you are ...
While your holding in the knob after lighting the pilot,their is a thermocoupler that is heating up and will hold automatically what your pushing in, that thermocoupler is defective
The oven has a flame detection installed that makes sure the gas turns off if the flame goes out. There are two component that do this. One is the flame detector and the other is the control device that turns the gas off,. Either one of these cold be faulty. The cheapest way is probably to replace the detector in the oven and if that does not work, replace the gas control device.
Hi there you need to change the ffd on your oven
FFd stands for flame faliure device. its like an temperature controlled switch. it is located in the oven and this device is what lets the gas go through once it has reached a certain temp.
It must only be done by a corgi qualified engineer and to be honest your loooking at about 100 pounds.
