Computers & Internet Logo
Question about Acer Computers & Internet
How can I enter my bios on an Acer Aspire 4743? It's writing 'bios shadowed' and 'video bios shadowed'?
Posted by Bwali Mwila on
ADMIN Andrew
    Top Expert:
  • Acer Master
  • 57,254 Answers
1helpful
Acer aspire 4743 not charging but all Okay.....
The solution to your problem lies in one of the following three areas:
1.) Your acer aspire 4743 charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
Blue sreen error in my acer laptop
go into bios,set it to defaults then install. try a fress partition, delete the old one and create a new one, there might possibly be artefacts from a previous bad install. I would test memory/hard isk for errors before I started installation if it has been running badly, problems here might be causing the BS, as might motherboard issues
Good Luck with it
My laptop is acer aspire 5542G, it is struck on bios shows the following : phoenix secure core(tm) NB copyright 1985-2008 pheonix technologies ltd. all rights reserved v1.05 cpu0=AMD turion(tm)...
Hi
you could try to press F8 on startup eg press power key then press F8 holding down for a few seconds and hopefully it will take you into some repair options
i would try the last known good configuration option to start with
then windows will restart and try to repair it back to when it was good
and if that dont work try the safe mode/system restore
hope you get it sorted
many thanks
My laptop says entering set up but does not enter. it says enter F2 for set up. when I press F2 key it says entering set up but nothing happens. When I switch on the laptop if I press the ESC key it says...
Nice way of experimenting , but if you want to continue working on your machine without errors, just load the default settings and save them while you exit. Also make sure you have the battery replaced on the motherboard.
2answers
I cant remember my password for bios
reset the CMOS battery by opening ya laptop!
2answers
Acer aspire one - its died!!!
If it was just the hard drive, I would expect the video to come on and say something like "no boot device."
However, since you went through the steps here and see absolutely no video (even none on an external monitor), I would suspect a motherboard failure.
Be sure that when you hooked up an external monitor that you pushed the Fn key and the appropriate special function key (maybe F7) that switches between the laptop and external monitor. If you have done that (pushed the combination several times to switch displays), then you can be pretty certain your video card (if a separate card) may be bad.
I'm not really sure if this machine has a separate video card. The specs say it's a ATI Radeon Xpress 1100. This leads me to believe it may be a separate card.
If it's just the card that went bad, you can replace it. Otherwise, the motherboard will have to be replaced.
Good luck. You can do that, but if you're not confident, you best take the machine to a repair shop.
My laptop shuts down and attempt to restart but unable to do so.
your bios battery is low but also you need to do a clean xp installation.
Steve Sweetleaf
Steve Sweetleaf
shadow
