I also get Error Code E5-222 and Error Code E5-221. any Idea what these codes are?I also get Error Code E5-222 and Error Code E5-221. any Idea what these codes are?
Glory UW-500/600 Currency Sorter (No longer available, please see UW-F) dead.
it needs service. take it to a shop and get some.
cleaning out is first. money is nasty dirty stuff.
I work for the former Brandt company, now called Glory.
Let me be clear on this. The Brandt/Glory company makes the best counters on the planet. That being said the model 1200 is the worst design ever. I never liked it and it's been last made 25 years ago.
Lets start simple. In the back of the machine there are 2 fuses. F1 protects the motor and is a 3 amp fuse. F2 is a 1/2 amp fuse to protect the display. Make sure they are good.
Next you'll have to take the back off to see if the belt is broke or the pulley fell off. Or, the motor plug has come loose?
Do a machine reset by unpluging the power cord. Then while pressing and holding the "C" key, plug the machine back in and wait 5 seconds. If the above does not help at all, you have more serious problems like bad motor, bad motor controller.
You can try calling me at nine8five 8ninethree 5two4one
Good luck
PSL stands for "position sensor-left". Check the left sensor for dust or some obstruction on that sensor. The operators manual will show you where that sensor is.
32 isnt a valid code for your model. Mitsubishi model WS55859 has only 5 possible codes they are 12, 21, 22, 23, and 24 Double check the code again and resond to this same post and i will assist you.
try to check it again as these are the only codes for your model.
3. Error Codes
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
“12” ... indicates no error has occurred.
“21” ... X-Ray Protect circuit.
“22” ... Short Protect circuit.
“23” ... Horizontal Deflection failure.
“24” ... Vertical Deflection failure.
This is such a little known, specialist machine, there is not much information on it.
https://www.google.com/search?q=Glory+WS...
