Sewing Machines Logo
Question about PfaFF Sewing Machines
Light Switch, Pfaff #70-112000-02 Do you have one in stock and how soon can I receive it.
Posted by Ardith Viste on
ADMIN Andrew
    Top Expert:
  • PfaFF Master
  • 57,457 Answers
We are FIXYA dot com. We don't sell anything. We only supply free information.
There are sellers in the link. The cost is $18. Delivery is likely 3 to 7 days.
https://www.google.com/search?q=Light+Switch%2C+Pfaff+%2370-112000-02
Posted on Oct 20, 2022
1helpful
I'm trying to find needles for my Pfaff Hobbymatic 875. Haven't had any luck. Do you know where to buy them? Thanks.
The Pfaff Hobbymatic Extra 875 uses standard 15x1 sewing machine needles. The needle you need will depend on the fabric and thread. You'll use a thicker needle for denim than for a lightweight knit. See https://www.sewingpartsonline.com/pfaff-875-serger-machine-parts.aspx?index=14 for a wide selection of different in stock needles.
I hope this helps.
Pfaff embroidery cutting blade
do you want a cutting blade?? have found a site that has spare parts for Pfaff machines - hope this will help
Parts For Embroidery Machines ... Edge Cutter Attachments ... We carry new and used machines from Singer, Pfaff, Durkopp Adler and many more. ... We stock a wide range of rotary, drag and tangential blades, sign blade holders and blades, ... www.sloanmachinery.com/
The memory board went out on my 2000 tiptronic 6270 a couple years ago. now the machine won't sew at all. the sewing light comes on, but not the lighted digital readout area. so , no sew. how do i...
There is a fuse in the the base plate
that has probably blown. It is soldered in and needs to be fixed by a Pfaff dealer on someone with access to the fuse. If you have the work done, make sure they replace a certain reisitor on the base plate at the same time to prevent this from happening again (per Paff). Sorry for the inconvenience, hope you are back to enjoying your Pfaff machine real soon.
Ruffler for Pfaff 7570 Machine
Try contacting a pfaff dealer. If they don't have one in stock they should be able to order one for you. If you're not sure where the nearest pfaff dealer, the pfaff website should have a list of dealers for your area.
1helpful
Need cutter blades for a Hobby Lock 796, where are they available?
http://www.sew4less.com/sitemap_products.php?BrandID=54&ModelID=725
A Pfaff dealer may also be able to order for you if their repair person does not stock this item.
Needs new needle bar, needles do not remain parallel with each othe. none in stock locally. Pfaff hobbylock 787, 788
Check out http://www.pfaffmachines.co.uk/partsDB/index.php?category=Needle_Bar_Parts
It looks like this site has everything you'd need for a Pfaff machine!
I am looking for a replacement timing belt for my Pfaff 230. It is double row with 73 cleats
Try this link. According to the website, they have kots of replacement belts and stock belts for the Pfaff models.
http://www.sewingmachineparts.net/index.html
1helpful
2answers
My PFAFF 1222 SE has a broken switch. I don't
I have many parts available for the Pfaff 1222 as well as many other Pfaff models.
I will also have power switches available for the Pfaff 1222 as well as other Pfaff models, and sold as a kit that you can install on your own with step by step instructions. The original power switch has been discontinued from the manufacturer of the power switch.
We have been in business since 1973, and we specialize in the Pfaff machines as well as stocking many parts for the various Pfaff machines - as well as other brands.
We service and sell NEW & USED & REBUILT Home sewing machines & related equipment as well as Industrial sewing machines, and we have a vast supply of PARTS and ACCESSORIES in stock.
I also have a Full Synthetic Sewing Machine Oil that I developed about 12 years ago with the assistance of two long time engineer friends - as I didn't like any of the oils that were readily available for sewing machines.
Please feel free to email me at: [email protected]
1helpful
Unable to get picture on LCD
Did you try the contrast light? It is a small dial right underneath the lcd screen.
Top PfaFF Sewing Machines Experts
Marvin
Marvin
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
