Earn income while simply working online. work from home whenever you want. just for maximum 5 hours a day you can make more than $600 per day online. From this i made $18,200 last month in my spare time. . . Check info here-------------------------------------------------->>> http://Www.RichApp1.ComEarn income while simply working online. work from home whenever you want. just for maximum 5 hours a day you can make more than $600 per day online. From this i made $18,200 last month in my spare time.
You can't post conmments that contain an email address.
Pressing the Clear/Back button when front cover is opened. press the arrow down key to show the appropriate toner, then press 1 to reset the bias, close front cover.
If you have replaced the toner cartridge but it is still displaying "low toner: Try the following:
Open the front cover of the machine and turn off the power
Hold down the "Go" button and power the machine back on, while holding down the button.
All the lights should light up, when they do release the button.
Press the "Go" button once and the lights will go out.
Press the "Go" button once or twice till the Toner/Drum/Paper lights are on again.
Now tap the "Go" button 6 time and all the lights should go out.
Close the cover and turn the machine off and then on again.
OR
Open the cover of the machine and remove the drum and toner.
Remove the toner from the drum unit and put just the drum unit into the machine.
The machine should indicate "toner empty".
Open cover and re install the drum and toner together - Close cover.
Canon iR3300 copier /image runner is a best machine which is not needed any expert mechanic. Thanks to the manufacturer.If the toner in the cartridge was completed a message may be displayed on the screen that 'refill the toner'. Even though there will be a small quantuty of toner in the cartridge the message may be appear on the screen. Please don't bother about this mesaage. You may think the machine be damaged some where else. You might have handling the 'motor bike' or 'scooter' and you may experienced about the resrve . i.e. even though there is some petrol in the petrol tank of vehicle , the vihicle may stops to work. After filling of the petrol the vehile may run as usual. So , after the reserve of toner in the cop[ier the machine will stops to work. The you have to refill the toner cartridge with the fine quality toner of 1/2 kg or with 1kg. The cost of the toner may be Rs.500/- to Rs.650/- depending on the quality and the company and availability of the toner in the market. The toner must be compatible with the iR 3300 copier. After purchasing of the toner you must shufle the toner bag up and down nearly (100) times , so that the toner in the bag may thouroghly mixed and see that there will not be hard particles. Then remove the front cover gently and turn the side levers 1). left lever to left side and 2). right lever to down side. Then gently drag the toner cartridge of only 3/4 size. Please don't try to remove the toner cartridge completly out side of the machine. The costliest cartridge and not avialability of the new cartridge in the market may be break.At the front and top of the cartridge , there will be small lever attached to the cover of cartridge . Just hold the front ant and top of the cartridge with middle fingers and thumb fingers either side of the cartridge by both the hands and just press the levers out side towards you with the fore fingers of both the hands.. Then drag the cover only 3/4 of cover out side towards yourself. Make a small hole at the corner of the toner bag and pour the toner gently in to the cartridge. while pouring the toner in to the cartridge gently move the cartridge inside and out side , so that the toner may evenly spread in the cartridge. After pouring of hole toner , close the cover the cartridge by pressing the edge of the cover from out side and then press the cartridge in to the machine and there after turn the levers in to the original position and close the front cover.
To reset the sensor after installing a new toner cartridge follow these steps.
1. With unit powered On, open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press 1,0 .
5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
6. Close cover and see if Toner Life End error message has gone.
Please note that this must be done with a new cartridge so the unit will see that there is toner in the cartridge.
In the box with new drum is manual how to reset this, however, will not show solution for this particular model. So you ned:
1. Open cover (as to replace drum or toner). On display you will get "Cover Open"
2. Press right arrow under LCD display.
3. Press 1 (digit one) on keypad.
4. Close the cover
When you take the toner cartridge off the imaging unit, is there magenta toner in the open slot of the IU? Assuming that there is nothing wrong with the toner cartridge, you are possibly looking at a bad engine control board.
