Photography Logo
Question about Photography
How much are motorized curtains? - Photography
Posted by uae curtain on
Don A
  • 3,517 Answers
Https://motorizedcurtains.ae/
https://designingidea.com/motorized-curtains/
https://www.amazon.com/Electric-Curtains-Automatic-Motorized-Compatible/dp/B09VNRBNCF
Quality, price varies. I am guessing your location. If correct, there are a number of other suppliers listed by Google in the area. The bottom two links simply are examples, informative but perhaps not in your area.
Posted on Oct 18, 2022
Why should I purchase a blackout curtain?
The black of blackout curtain inserts woven into the material increases the curtain's blackout strength. The only complaint we had is that the black lining doesn't go all the way to the top of the drapes. Thus, the light will pass through the top portion of the grommets. Not a significant flaw, still, we chose to be picky. If you are a light sleeper or need a curtain to create a cave-dark environment for your home theater or computer operation, this could be a great choice. That's why you can purchase a blackout curtain. This one made the cut with its terrific ability to cancel out 99% sunlight and about 60% external noise. The strength of Utopia Bedding Curtain lies in the fabric it is composed of. https://depthreviews.com/best-blackout-curtains
May 28, 2018 • Photography
3answers
What are the most effective UV-blocking curtains to use for preserving antique fabrics and books?
Curtain is essential in our day to day life. Its like a fence that our home is protect from various things like harmful UV sun rays, external noise and keep privacy from others. So, its a big matter to choose a right one to decor or keep the home as a nice pattern or shape. I recommended that Blackout curtain are easily block out maximum sunlight and lower external noise is really adorable for any home. I think blackout curtain is the best for light sleeper and who's have insomnia. Because of blackout curtain make the room environment as a dark cave that easily brings sleep. https://depthreviews.com/best-blackout-curtains
Max harvest retrying
Likely cause,
1. Ice bridge thickness too small, not enough ice to open curtain.
Solution, Check and adjust if needed.
2.Ice bridge thickness too large, ice frozen to evaporator frame.
3. Purge valve dose not open, water melts ice bridge, not enough ice to open curtain.
Solution, Check purge valve.
4. Incomplete ice formation.
Solution, check water distribution for partially plugged holes.
5. Curtain out of position.
Solution, check curtain for swing restriction.
6. Curtain switch dose not open when curtain does.
Solution, Check switch with ohmmeter.
7. Machine in very cold ambient area.
Solution, Move machine to warmer location.
8. Hot gas valve dose not open.
Solution, Check hot gas valve, check controller using test mode.
9. Harvest assist probe out of position - ejector pin not retracted.
Solution, check harvest assist mechanism-spring should retract pin.
10. Damaged evaporator.
Solution, Check evaporator surface now would be a good time to make sure evaporator plate is not dirty this will cause ice to hang up on evaporator plate also check plate to make sure all cross points are not loose.
11. Fan motor stays on during harvest.
Solution, check controller using test mode.
How to install a curtain?
Do you mean the shutter curtain on your camera? If so, please specify the make and model of your camera. If you mean some other type of curtain (shower, window, etc.), please specify the type of curtain.
Feb 14, 2013 • Cameras
Screechy shower curtain
they do make chrome plated, plastic curtain rings.
Apr 12, 2009 • Home
2answers
How to Install Shower Curtain
If you are going to use both a shower curtain and a shower liner, you have two options for installation. You can either use one rod and one set of rings, or you can use two rods and two sets of rings. If you used one rod, line up the liner and the curtain so they are facing one another and thread one ring through each of the corresponding grommets on the both the liner and the curtain. The curtain liner will move as one unit. If you use two rods, you need one set of rings for each, and the liner and the curtain will move independently.
Top Photography Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Are you a Photography Expert? Answer questions, earn points and help others
