Computers & Internet Logo
Question about Logitech Computers & Internet
Water damage in Logitech Ultra Thin i5 keyboard.
ADMIN Andrew
    Top Expert:
  • Logitech Master
  • 57,441 Answers
Posted on Dec 15, 2022
When I type on my logitech ultra thin keyboard cover it gives a different character than the one I typed. Is it possible to repair?
not al keyboards are the same. even though you have a qwerty key board the country language moves the actuyal key location around. I am thinking that the keyboard you have is set for england and you want a usa set keyboard or sime other country keybhoard. The boards are set out the same but certain keys print not what you expect. Go on the web and tyep in keyboard layout for more information on how to set it out. I have done it but it was so long ago that I have forgotten how but I do remember that the process is really quite simple.
1helpful
Using the keyboard for iPad not typing on the screen
check the manual...!
depends on the model - but it works with bluetooth- see a sample :
put the iPad in the slot built into the keyboard, and pair it with your iPad via Bluetooth
On your iPad, tap the Settings icon and then tap Bluetooth. Make sure Bluetooth is On.
Connect the Logitech Ultrathin Keyboard Cover i5 Logitech Support Article using-keyboard-ipad-not-typing-screen-jq4dbyibaqf10wv4m2e43laj-1-0.jpg using-keyboard-ipad-not-typing-screen-jq4dbyibaqf10wv4m2e43laj-1-2.jpg
Www logitech com ithink
If the above URL is what you are trying, try with; http:// www.logitech.com or https://www.logitech.com.
You can also avail our technical support by visiting our website: http://www.vtechsquad.com.
Hello. Logitech G11. some keys are not working. Page up, 4 on num pad and arrow up. System is Windows7 32 bit. what should I do? the latest driver from the official site is installed. thanks
I just got one, and it's waffer thin plug-in's on the circuit board. their very fragile and obviously easly disconnected from their micro thin carbon strips. What it needs is opened up and try reseating the plugs. Be very careful.
I have a labtec ultra flat keyboard, and the multimedia key does not function, and I cant seem to find amy drivers for it. It worked on the previous version of Win 7, but on this version seems that...
In 2001, Logitech bought Labtec. Logitech handles all the tech support for the old Labtec products.
Start your search for Info > http://support.logitech.com/en_us/product/ultra-flat-keyboard
3helpful
2answers
How can I clean the rubber part of this keyboard? It's gotten sticky and dust collects to it.
The "rubber" is just a thin coating (at least on my diNovo Media keboard). It gets sticky over time and can be removed completely with isopropanol (2-propanol) and paper towels. The alcohol can be purchased at your local pharmacy.
You have to be patient, it takes some effort to fully remove it.
Hello expert
try cleaning it before you mess with any settings.
Cause:
Your keyboard or number pad may collect dust and other deposits from regular use. Occasional maintenance helps keep the device looking clean and functioning properly.
WARNING: Before cleaning any electrical device or equipment, ALWAYS remove the device from its power source.
Solution:
  • For cordless keyboards or number pads, remove all batteries before cleaning.
  • For the diNovo Edge (a rechargeable keyboard with a built-in, non-removable battery), or any other similar device, switch the keyboard OFF before cleaning.
  • For corded keyboards or number pads, shut down your computer and disconnect the keyboard from the computer before cleaning.
Keyboard and number pad cleaning suggestions:
  • Use compressed air to blow dust and other debris from between the keys. Logitech suggests using an air duster squeeze bulb specially made for keyboard cleaning to limit the force of the air pressure.
    NOTE: Avoid using high pressure air hoses and nozzles. Excess air pressure can remove keys or cause other damage to your device.
  • Use a small tipped vacuum cleaner to remove dust and other debris from between the keys. Logitech suggests the use of a small tipped vacuum cleaner specially made for keyboard cleaning. Many come with USB power cords and can run off your PC or laptop.
    NOTE: Avoid using vacuum cleaners other than the type previously described. An excess vacuum level and/or large vacuum tip can remove keys or cause other damage to your device.
  • Use a dry, lint-free, non-abrasive micro-fiber cloth to gently wipe clean the surface of your device. Logitech suggests using cloths which are specially made for keyboard cleaning.
    Note: Avoid using dusted disinfectant cloths or cloths dampened with liquids unless specifically designed for keyboard cleaning. Many cleaning solvents, chemicals, and other liquids can cause electrical and/or material damage your device. This includes leftover residues which can eventually damage your device over time.
Additional information:
Many consumer electronics stores and online re sellers offer third-party computer cleaning kits which include dry wipes, swabs, air duster bulbs, and micro-fiber cleaning cloths. Some higher-end cleaning kits come with keyboard vacuum cleaners, and/or product-safe disinfecting liquid for dampening wipes, for use in disinfecting the surface of the device. These liquid disinfectants are supposed to be non-conductive electically; quickly evaporate from the sevice and leave no residue. Logitech suggests you make sure these characteristics are plainly stated and guaranteed on the product package. These specially made keyboard cleaning kits are highly recommended.
IMPORTANT NOTES:
  • DO NOT pour any liquids onto the device.
  • DO NOT submerge the device in any liquids.
  • DO NOT use a dishwasher, ultra-sound cleaner, or any other washing machine to clean your device.
  • DO NOT remove keys from the device.
  • DO NOT use cleaning solvents. Many cleaning solvents contain caustic chemicals which may cause damage your device.
  • DO NOT use drying machines, fireplaces or ovens (even set at lowest temperature) to dry moisture from your device.
Removing keys; submerging or pouring liquids on your device; using washing machines; exposing your device to excessive heat; or using caustic cleaning solvents may cause permanent damage to your device and will void the warranty.
Logitech Ultra-Flat Keyboard not recognised by system
Found that the .exe file rundll32.exe was missing from C:\WINDOWS\system32 location but found another genuine Microsoft created copy in another directory and copied it across the the directory listed above.
Top Logitech Computers & Internet Experts
Marvin
Marvin
Steve Nordquist
Steve Nordquist
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
