Glenn Harris Posted on Oct 16, 2022
Bugera 6262 seems to have excessive static on lead channel, is that normal?
Does anyone have a service manual or schematics for amplifier - BUGERA model 333xl?
Question moved from 'Cars and Trucks' to 'Bugera 333XL'.
https://www.google.com/search?q=BUGERA+model+333xl+schematics+for+amplifier
No Service manual, but you could ask.
Download Center - Bugera
https://www.bugera-amps.com > downloads
Find and download product manuals and drivers for your Bugera product here. ... 12345...48. Bento Box. Service. We love to help you.
Where can I get a schematic diagram of the Bugera 6262 Infinium Guitar Combo Amplifier?
Bugera - MUSIC Group
https://www.music-group.com/brand/bugera/home
Notice of Scheduled Maintenance. This is to advise you that our system will be unavailable on Saturday, January 9, 4PM - 6PM, SGT. Please plan accordingly.
Page 44: Bugera Users' Militia (for all things Bugera) @ Ultimate ...
www.ultimate-guitar.com/forum/.../index.php?t...
Ultimate Guitar Archive
Aug 17, 2011 - 100+ posts - ‎68 authors
I really like the cleans on this amp, and I don't consider using the overdrive.. so better tubes will ..... Its a 6262 212 combo ... 6262-212 INFINIUM 10/06/2011 ..... is there aschematic for this mod somewhere floating around? Page 48: Bugera Users' Militia (for all things Bugera ...
100+ posts
Jul 15, 2013
Bugera TriRec - First pricing (US) @ Ultimate ...
100+ posts
Apr 19, 2010
More results from www.ultimate-guitar.com
Rig-Talk • View topic - Bugera Amplifiers
www.rig-talk.com/forum/viewtopic.php?t=138566&p=1605914
Jun 14, 2013 - 50 posts - ‎12 authors
Printer not printing first 3 left characters
There are 2 kinds of 6262 that have vastly different hammer asm, but most likely you have a hammer issue. If it is a 12 or 14 you would need
IBM 5665720 HAMMER COIL 6262 Refurbished
It can also be a cable or card, but those normally have errors reported.
PS I don't know why the wrong pick is coming up for that part on fixya, but the site has no pic as the part is super old.
Broken input
The Bugera 6262 takes a standard 1/4" jack -- readily found online, music stores, or even Radio Shack. If you can solder, this is a basic fix, but will require that you pull apart the amp a bit. If you don't feel comfortable doing that, then I would suggest sending it in for repair. Try finding someone local to do this, rather than shipping it to the Behringer repair center. Best of luck!
Bugera 1960A - channel 2 has very low volume even when vol2 knob is turned fully UP!
The user manual is located at: http://www.bugera-amps.com/PDF/Downloads/1960_P0671_M_EN.pdf on page 5; When the HIGH 1 and LOW 1 (or HIGH 2 and LOW 2) connectors are used simultaneously, their sensitivity is the same (both LOW). This may be your problem however--- Try swapping input chanels to see if the problem follows ther cable or is in the amp.
Assuming it was working before, you may have a short in the cable or a bad component or tube in the amp. Tubes can be difficult to come by. If the other channel works correctly, It may be one of the small tubes. Hope this helps
2helpful
Bugera 333xl every few seconds there is a loud buzzing. from
It looks as though you have ripple noise that amplifies into the output. First of all check if the mains voltage is going down to produce the low voltage hum. If not you will have to check the DC filter capacitors , couple in parallel to confirm the capacitor. IF the buzz is still coming through then you will have to isolate the preamp and wait it the fault is coming in. If not connect the preamp output to another amp to hear the same buzz to confirm the preamp to be faulty. If so you will have to trace by a voltage check when the buzz occurs to confirm if the preamp IC or the selector Ic is faulty. Some logic IC's can also produce this noise on static switching. If teh noise is appearing on both the channels, then I would still bet on the power section. So check once again on the rectifier/ regulators and capacitors. Hope this advice helps. Good day
Hi, All our channel switch is broken, so
Try resetting up the printer whilst attached to that machine and reinstall the printer driver.
The footswitch for bugera 6262 valve amp seems to have a logic problem. The clean channel leaves 'lead and reverb' leds lit on footswitch, pressing 'lead' lights the crunch channel on the amp... and reverb...
Hi ! Check and make shure that the cord conections between the pc board on the backplate of the amp to the logic board are firmly pushed in there slots.
Good luck , Stefan from Sweden
 Grubhead
Grubhead
SmartAviator
SmartAviator
