Tablets & eReaders Logo
Question about Telefunken Tablets & eReaders
Telefunken 3g tablet not switching on and it sometimes charges when i plug it on the charger and when you try to switch it on it stops charging for a long time and the process repeats again and again
3g telefunken tablet
Posted by maria manzini on
Joliver C. Navida
It sounds like there may be a problem with the battery or charging system of your Telefunken 3g tablet. Here are a few things you can try to troubleshoot the issue:
  1. Make sure that you are using the correct charger and cable for your tablet. If you are unsure, check the manual or contact the manufacturer for recommendations.
  2. Try a different power outlet to see if the problem is with the outlet or the charger.
  3. Check the charging port for debris or damage. Clean out the port with a soft-bristled brush or compressed air, and make sure that the charging cable is securely plugged in.
  4. If the above steps don't work, try a factory reset of your tablet. You can do this by holding the power button and volume down button at the same time until the device turns off. This will erase all data on the device, so make sure to back up any important files before doing this.
  5. If the problem persists, it may be a hardware issue and you should consider taking the tablet to a professional for repair or replacement.
Please note that these are general troubleshooting steps and the solution may vary depending on the specific model of your tablet. Also, if the tablet is under warranty, contact the manufacturer for assistance.
Posted on Jan 13, 2023
MY MOBICEL ECHO TABLET DOES NOT SWITCH ON.CONNECT CHARGER DOES NOT SHOW CHARGE ICON.IVE ALREADY REPLACE CHARGING PORT STILL NOTJING
Hi all I've got a mobicel tablet enco and it just went dead so I plug it in and it shows charge and goes off again and comes on to charge again the charge ring block isn't broken I tried charging the charger and bought brand new charger it still does the same what can it be now it just doesn't charge at all
My tablet will not turn on or charge at all!
Are you using the supplied Samsung charger? Many times if your not using it, the tablet won't truly charge.
1helpful
2answers
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
I have a toshiba 7inch tablet which has stopped charging it has no light on the tablet when its plugged in and switched on
Check the charger first. Plug it into something else. See if it charges. If you can not do that take it to a store like best buy and see if the have a replacement charger that you can try. The plug in the tablet can come loose if it is dropped while plugged in and if that happens you are in the market for a new one.
Trio Quad Core Tablet will not charge
Either the charger or the battery is faulty, from the sound of your fault description. If the tablet will turn on and run normally when the charger is plugged in, then the problem most likely lies with the battery. If it will not run even when the charger is on, then the charger is most likely the cause of the fault. If your tablet is still under warranty, either problem should be repaired free
2answers
I turn my tablet on then it switches it self off
Sounds like it does not have enough battery power to stay on. If you have not tried to charge it, you should try that first. If you have, it sounds like it is not getting charged or not holding a charge. Could be bad AC power source, bad charger, bad charger connection or bad battery. Take steps to confirm that each of these are good. If all of these are good, sometimes the tablet can become so discharged that it will not allow itself to charge. When they are in that state, sometimes you can trick them into charging again by repeatedly disconnecting and reconnecting the charger as follows: With charger plugged in to AC power source, connect the charger to the tablet. Pay attention to the screen or LED or whatever indicator your tablet has to let you know it is charging. You may see it momentarily indicate charging, or maybe not at all. Then unplug the charger from the tablet then immediately plug it back in and pay attention for the charge indication again. You may have to do this a bunch of times (like 20) until you see the indication that it is charging. When you do get the indication, stop unplugging and re-plugging and let the tablet charge for 24 hours (to a full charge). This trick doesn't always work. Sometimes the battery or charging circuit or an internal connection is bad and no amount of unplugging/re-plugging will fix a hardware problem.
My 7 inch Samsung galaxy tablet will not come on.
have you tried turning off tablet with charger plugged in and letting it charge up. You should see a battery symbol come onto the screen with a pulsing level indicating the battery is being charged. hold in power till unit turns off then plug in charger cable into tablet and switch on charger at power point . Do not try and push power switch to power up tablet see if screen indicates charging is occurring. I have experienced this exact problem on a samsung tablet !
3helpful
Kindle 3g screen is blank can get it back on
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
Top Telefunken Tablets & eReaders Experts
Marvin
Marvin
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Telefunken Tablet and eReader Expert? Answer questions, earn points and help others
