Question about The Watches
Hi all, the paradox alarm that I have is MG10LEDH. The alarm keeps going off after I set the arming mode on every hour at the same time. This is the second time it happen. The first time the technician came and said someone set the test mode on so it will go off every hour. He just punch in some code and the problem was solved. it was a easy fix but was so expensive I just wanted to know what code should I use to stop it from going off. Thank you so much
I'm sorry to hear that you're having trouble with your Paradox alarm. Unfortunately, without access to the specific manual or programming instructions for your MG10LEDH model, I am unable to provide you with the exact code to stop the alarm from going off every hour.
However, it is possible that the issue may be related to the alarm's timer settings or an automatic test mode that has been activated. You may want to try checking the alarm's programming manual for instructions on how to disable any automatic test modes or adjust the timer settings.
If you are unable to find a solution on your own, I recommend contacting the manufacturer or a certified Paradox alarm technician for assistance. They should be able to provide you with more specific instructions or diagnose and fix any issues with your alarm system.
Posted on Mar 14, 2023
