Ovens Logo
cliff biddle Posted on Oct 11, 2022
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I purchase a Zenith 50 replacement oven element?
Zenith 50 lower oven stopped heating today oven otherwise in good order. Is there a part number I need?
ADMIN Andrew
Level 3:
Top Expert:
  • Ovens Master 66,745 Answers
  • Posted on Oct 11, 2022
ADMIN Andrew
Ovens Master
Level 3:
Top Expert:
Answers
66745
Questions
Helped
5042702
Points
378571
Fan oven side element required Scandinova DF902SS range cooker
If you need to replace the side heating element in your Scandinova DF902SS range cooker, the first step is to locate the part number for the element you need. This can usually be found in the user manual or by contacting the manufacturer or a licensed service provider.
Once you have the part number, you can purchase the replacement element from a reputable appliance parts supplier or the manufacturer directly. Be sure to choose the correct size and model for your oven.
If you're not comfortable with DIY repairs, it's best to have a professional technician handle the replacement for you to avoid any potential safety hazards.
Mar 07, 2023 • Ovens
1helpful
My Contertop convection oven..model #TSSTTVPZDS....has a failed top heating element...I need a replacement part number ..or informarion on how to order it..plz
To get a replacement heating element for your Oster TSSTTVPZDS countertop convection oven, you can try contacting the manufacturer's customer support team directly, either through their website or by phone. Alternatively, you can check with online retailers like Amazon or appliance parts websites for compatible replacement parts.
When contacting the manufacturer, be sure to have the model and serial number of your oven ready, as well as a description of the part you need. They should be able to provide you with the correct part number and information on how to order it.
If you choose to order from an online retailer or appliance parts website, you may need to do some research to ensure you are getting the correct part for your specific model of oven. Make sure to double-check the compatibility and return policy before making your purchase.
Feb 27, 2023 • Ovens
Smeg gb-ie
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jul 12, 2013 • Smeg Ovens
The heating element in the lower part of the oven burned. I was almost like a welding rod, it kept burning even when we had the oven off. I turned the power off at the fuse box before it finally stopped....
This sounds more like the electric control dial thermostat, keeping power on at the element, both element and control dial will need replacing
3helpful
Convection upper oven not heating. lower oven working fine. blower on upper oven working fine and pre heat shows when oven us turned on but upper oven does not heat.
I Have worked on quite a few of these in the last few weeks, i have found that about 50% of these problems are caused by the control board and the other 50% caused by the thermal fuse, you can check the fuse by removing the unit from the wall and checking for continuity at the thermal fuse. If the fuse is in fact ok then it is the board that is not sending the correct amount of power to the elements. So the Power Control Board is what will need to be replaced, you can purchase both of these parts at, http://www.reliableparts.com/ by using your model number.
Please rate my solution if it was helpful to you.
If you need more in depth information or pictures on how to remove and take this machine apart, feel free to ask.
Thanks, Repairman45
1helpful
My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
Oven functions
Oven light.
Upper and lower heating elements.
(Conventional cooking).
Upper and lower heating elements with fan.
(Fan assisted cooking).
Lower heating element with fan.
Inner grill heating element.
(Radiant grill).
Full grill heating element with fan.
(Fan grill)
Rear circular heating element with fan.
(Fan forced cooking).
http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
Oct 10, 2009 • Ovens
Oven does not heat up beyond 240 degrees, which takes a long time
You have either a burned our lower element or a wire has burned off at the terminal for that element. The good news is that the lower element is cheaper.
4helpful
3answers
Fridgiaire Gallery series Model GLEB30T8CBA lower elements dont work
I replaced the relay board for the top oven (the one with the transformer) and it works properly now. My issue was only for the top oven so you probably have to replace both relay boards since both ovens have only the top element working.
318022002 is the part number for the relay board with transformer
318022001 is the part number for the relay board without transformer
Yes the one without the transformer is more expensive for some reason.
The boards are on the top of the oven, I was able to pull out the oven about 75% of the way out of the cabinet and easily get to the boards. Just unplugged the connections and plugged them into the new board.
To get the oven out there are two small screws that go into brackets inside the top oven door. Highly recommend taking the doors off the oven to pull it out, much easier to work with.
NOTE: On my old board I noticed one solder joint that was burned out and I since I already had the new board I just replaced but you might want to check that first and see if just a solder fix gets you working again before you spend $$ on a new board.
Heating element in GE Range Oven
get the model number and order the exact repacement bake element
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
