If the power button on your Nokia C200 is not working, there are a few steps you can try to troubleshoot the issue:
Check for physical damage: If the power button is damaged or broken, it may not function properly. Inspect the button for any visible damage or debris that may be preventing it from working.
Clean the button: If the power button is stuck or not responding, it may be due to dirt or debris lodged in the button. Use a small brush or toothbrush to gently clean around the button and see if this resolves the issue.
Check the button connections: If the power button is not working properly, it may be due to a loose connection or malfunctioning component. Check the connections between the power button and the rest of the device to make sure they are secure.
Reset the device: If the power button is still not working after trying the above steps, you may want to try resetting the device to its factory settings. To do this, go to "Settings," then "Backup and reset" and select "Factory data reset."
wake the screen then press the power button to start power down. Then long press the pop up power down button til a prompt appears to reboot into safe mode. Select ok and then use your phone in safe mode. If it works without those errors then there is some app affecting your other functions of your phone.
Have you disabled apps on your phone that came on your phone?
my phone does this ever so often... you will lose all the data on the phone. with the phone off take the sdd card out and then while holding the volume button (+ or - changes from phone to phone... hold the volume camera and power button and wait for the screen you dont ever see, if you stop holding or hold the wrong volume button it will not work... then when that screen pops up hit your menu button on the touch screen, use the volume button to scroll down to system restore or what ever its called and select it with the camera button... then reboot your phone.
Furbys have a very small reset Button under the battery cover , on the lip of plastic that surrounds the batteries , hold this down with something sharp for a few seconds.
The Nokia kit has locked up, you will need to remove power from the kit for a few minutes to allow it to reset. If you do not know where the fuse or control box is you can try disconnecting battery on car but check with your vehicle manufacturer as some cars are sensitive.
my nokia x3 buttons have stopped working apart from the power button can you help me resolve this please. The beep sound is present while navigating the keys.
Nokia 6110 Secrets: *#06# for checking the IMEI (International Mobile Equipment
Identity) Information you get from the IMEI: XXXXXX XX XXXXXX X TAC FAC SNR SP TAC = Type approval code FAC = Final assembly code SNR = Serial number SP = Spare *#0000# To view Software Version. *#6110# Try this code if the above code doesn’t work. #746025625# [*#SIM0clock#] Checks if the SIM clock can be stopped. SIM clock stop is a
kind of stand-by mode which will save battery time. This code doesn’t
work with software version 4.59. *#92702689# [*#war0anty#] You don’t need the warranty-codes
any more – you can just scroll through the information like in any other
menu. It has the same data as 81xx and 31xx phones (with “Edit” button
for purchase date, and “User data transfer”). Menu: 1: Displays Serial Number. 2: Displays the Month and Year of Manufacture (0997) 3: Displays (if there) the date where the phone was purchased
(MMYY) you can here set the Purchasing Date (Warning: You can only do
this once – so be careful what you write…) 4: Displays the date of the last repaired – if found (0000) 6: Does anyone know if this is for upgrading the phone’s
EEPROM?? (Transfer user data?) Enhanced Full Rate
Codec (EFR): On: Enter *3370# and EFR will be activated after a reboot of
the phone ( consumes more power ) Off: Enter #3370# and EFR will be switched off after a reboot
of the phone. Half Rate Codec: On: Enter *4720# and Half Rate coded will be activated after a
reboot of the phone ( better standby time ) Off: Enter #4720# and Half Rate coded will be de-activated
after a reboot of the phone
So do I,hehehee... well,now tray to do formatt.here is the way : First,back up your phone contact (It will be loose) ,switch off your phone, press and hold * button, 3 button, green or call button than press and hold power on button.wait for a while till show Nokia logo than twingkling.now you may release your fingers.if it work your screen will show name of Country City where you were.Do again the process if not show name of City.Good luck..
